Old 03-31-2014, 09:20 PM   #1
1971 27' Overlander
st. louis , Missouri
Repairing black water tank?
Hey All,
Just curious if any of you have had any luck repairing cracks (or not) in the black water tank? Here's a pic of mine. Just wondering if an epoxy will work on this?
THanks!
STLRooster is offline   Reply With Quote
Old 04-01-2014, 10:13 AM   #2
The tank looks unreparable. The crack goes around the curve of the tank. I have had trouble with epoxy bonding on some types of plastic. 40 or so gallons of waste in the tank generates some pressure at the bottom.
You don't want a failure with a black water tank that would be an unpleasant mess to clean up.
handn is offline   Reply With Quote
Old 04-01-2014, 10:34 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
That tank is likely made of roto-molded poly-ethylene, and as such, there aren't many glues that will stick to it. Probably your only chance of repair would be to find someone with plastic welding capabilities to weld up the cracks, and then weld a patch over the cracks for added strength. I've tried a little plastic welding, and it is more art than science.
good luck!
Old 04-01-2014, 10:36 AM   #4
1976 27' Overlander
Hartford , Alabama
STLRooster,
I'm pretty sure they were using high density polypropylene tanks for everything back then. Almost impossible to use any kind of adhesive. If that is the top of he tank I might risk having it welded by a professional, if it is on the bottom, I'd just replace it. They aren't that expensive.
Valacidor is offline   Reply With Quote
Old 04-01-2014, 10:43 AM   #5
Originally Posted by STLRooster View Post
Hey All,
THanks!
Plastics then were very different from today.
A fix, especially with epoxy, would be very temporary, at best.
A fiberglass replacement is available.
Old 04-01-2014, 11:34 AM   #6
1971 27' Overlander
Thanks for the replies everyone. Just thought I would give it a shot. Looks like a shiny (not for long) new one is on the way!
And...to answer the question, it is on the bottom of the tank.
Greg
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-02-2011 12:51 AM
water inlet to black water tank blocked mbarker Waste Systems, Tanks & Totes 4 11-22-2009 09:54 PM
Tank Gauges, Repairing of Bedford General Motorhome Topics 3 07-24-2006 04:20 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 07:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-30-2005 12:03 AM
