Old 11-06-2008, 11:36 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Repair/Replace tank valve
The valve on our 1984 MH's propane tank leaks. I discover this when I removed the cooktop in preparation for installing a new SMEV unit. Although I shut the valve on the tank completely off, there was still a slight flow of gas from the supply line for the cooktop. I purchase a plug for that line and stopped the flow.
BUT, it seems like I really should be able to shut the gas off. What's involved in repairing/replacing this valve. Is this something I should try? If not what type of service business could/would do this?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 11-06-2008, 12:15 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
Gas Leak
With the main valve at the tank OFF, you might want to run something that burns gas to empty the lines. Then after a while, without turning the valve on, see if you can get that same appliance to start back up ( a day or so). In other words see if the line is filling back up. Just smelling gas in open lines does not mean you have a leak. The smell of gas permeates the walls of the gas lines and you will have that smell.
If you are then sure it is the main valve, an RV dealership should be able to change that valve. We do it here all the time. It is not all that hard. You have to drain the tank, and take any protector shelf out of the way. Then you get a wrench and take out the valve. You don't want any sparks. I say again, you don't want any sparks!!!!!!
Here is a link to the valve.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 11-06-2008, 12:49 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Are you sure the valve is leaking and not just the gas remaining in the lines bleeding off one you removed the stove.
The way to check is remove the hose at the tank and spray a soapy solution across the valve opening. If you can not keep the valve covered with the soap you have a leak. I would be surprised if the tank valve is leaking.
If you do have a leaking valve take the tank to any propane dealer for a replacement. If you do transport the tank with a leak do it in a pick up truck not in your car.
2004 Excursion 4x4
Old 11-06-2008, 12:52 PM   #4
Dan@LED4RV's Avatar
If I were going to change the main valve I would also change the relief Valve
Here is a link to the Relief Valve.
Dan
Dan Brown
Denton NC
Old 11-06-2008, 04:03 PM   #5
guy99's Avatar
Images: 16
I'm very sure the valve is leaking, as is the RV Tech I had check my installation for safety.
I lit my old cooktop, then turned the tank valve off, then allowed the stove to burn out. Removed stove and had strong propane smell. Put plug in cooktop connection. Smell dissipated then stopped. No more odor that day or the next until removing the plug when the odor immediately appeared. Hook up to new cooktop, order gone.
Old 11-06-2008, 04:05 PM   #6
guy99's Avatar
Images: 16
This tank is in a motorhome and quite large. I need the valve replaced with the tank installed in the motorhome.
Old 11-06-2008, 04:17 PM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I'd take it to a full-service propane company, not to an RV outfit. You may have to visit a couple of them.
If they have to remove the cylinder, go ahead and have them clean and paint it at the same time.
Lynn
WBCCI 21043
Old 11-08-2008, 10:59 AM   #8
guy99's Avatar
Images: 16
Source for LP Tank Valve?
Dan
OK, I ordered the Relief Valve and the Main Valve.
Looks like I'm going to have to find a RV shop to install them since neither of the local Propane companies will work on RV's.
Does anyone have a source for the tank gauge? Seems like a good idea to replace it while I'm replacing the valves.
Old 11-08-2008, 11:30 AM   #9
HowieE's Avatar
Images: 12
I think I would remove the tank and take it to a propane shop. I haven't found many RV shops I would let work on my RV let alone propane
2004 Excursion 4x4
Old 11-08-2008, 01:21 PM   #10
guy99's Avatar
Images: 16
This tank is quite large - I just filled it from empty and it took 26.4 gallons. Not really sure if I am up to removing it and man handling to the propane place. The there is the issue that the shut off valve leaks... Even if the tank was 'empty' there would still be residual gas.
Also, I asked the local guy if I could take it off of the MH and bring it in. They said no.
Old 11-08-2008, 02:12 PM   #11
HowieE's Avatar
Images: 12
Not sure what kind of propane shop you have in Ca. but replacing valves is a common practice since the new valves were introduced a few years back.
The tank will have to be empty before the valve is removed. As long as the local valve on each appliance is working I would use the gas you just bought and continue to look for a more cooperative propane shop.
Maybe contact a National Propane Asso. for advice on a member willing to work on a tank.
2004 Excursion 4x4
Old 11-08-2008, 02:18 PM   #12
guy99's Avatar
Images: 16
In a few weeks we'll be heading for Mexico, traveling through Arizona. I expect that I should be able to find someone to take care of this for me in Quartzsite or Yuma.
Old 11-08-2008, 02:40 PM   #13
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
You have an ASME horizontal tank on your motorhome, don't you? You might give the local forklift dealers a call and ask who they have service their built-in tanks on their big forklifts. That would be who I would choose to have examine my tank. There is no way you are going to horse that two hundred pound tank out of your MH by yourself!
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Advice re: replace or repair of BLK tank vintagemike Waste Systems, Tanks & Totes 2 04-10-2008 06:55 AM
Black tank valve replace Ramp Waste Systems, Tanks & Totes 6 12-24-2007 11:44 AM
Tank repair or replace? FreshAir Waste Systems, Tanks & Totes 13 10-10-2006 11:38 PM
Shower Mix Valve Repair/Replace?? Condoluminum Fresh Water Systems 8 05-19-2006 06:00 PM
Black Tank Valve Repair 87MH Waste Systems, Tanks & Totes 4 01-27-2004 06:47 PM
