Old 04-03-2008, 08:00 AM   #1
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
Regulator Mounting?
Can a regulator be mounted at an angle, or do they have to be mounted vertical?
Any problem mounting it in front of the tanks, closer to the hitch ball, rather than behind which is most common?
Thanks - Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 04-03-2008, 09:11 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
The propane tank regulator has a vent which has to be mounted downward. If you'll look, the vent is a small looking hole with a screen in it. Most regulators also have an arrow that points the direction also. There should be no problem associated with mounting it nearer to the front of the tanks.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 04-03-2008, 11:27 AM   #3
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
I've seen the vent. I am guessing the angle I am thinking will be about 30 degrees from vertical.
D
Mounting televisions DrPlay Audio, Video & TV 7 02-14-2008 08:30 PM
tv mounting katsix Audio, Video & TV 4 01-01-2008 08:01 AM
Television Mounting jrk247 Audio, Video & TV 5 08-28-2006 03:41 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
