Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 10-26-2009, 04:10 PM   #1
Profile:  1977 27' Overlander
Beatty , Nevada
Regulator Low Pressure / Water Heater Burner
Searched for this but couldn't find specific information so here goes. Have a 77 Overlander which I was given ( yes given ) a few months ago. Rig has been sitting in Death Valley, CA for at least 8 years w/o being used and may have sat for sometime before. Needed to get the WH going last week (Atwood G610 w/ Jade control). Leak tested all lines, removed all internal WH piping and vacuumed, blew out, inspected, etc. before trying to fire unit. Gas valve was kaput so replaced w/ new Robertshaw control. Now unit fires great EXCEPT for some bizarre behavior at the air shutter on the burner. Ocassionaly the flame will blow back clear to the gas valve orifice and while burning there it makes a chattering noise. Then, flame goes back to normal position and all is well. To me this is acting like low gas pressure. The regulator (a fischer) is original so I'm wondering if I should just replace it w/ a Marshall since the fischer has been sitting so long. TIA
77Overlander is offline   Reply With Quote
Old 10-26-2009, 04:28 PM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
I would check the flue in the heater first to be sure there is not an obstruction. The regulator should not effect the flame to cause it to blow back once it is lite.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Water Heater Adjustment? Gas Pressure too low? chasrahm Water Heaters, Filters & Pumps 1 08-10-2009 11:27 AM
Is the water pressure regulator really necessary? page.crow Water Heaters, Filters & Pumps 17 05-02-2009 04:18 PM
Water pressure regulator IndyAnne Fresh Water Systems 14 04-15-2008 01:26 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
Water pressure regulator? yukionna Fresh Water Systems 6 08-21-2005 01:47 AM
