Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 09-03-2009, 02:29 PM   #1
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Regulator leak or tank purge
The pin hole under the top part of the regulator is purging propane, hissing it. Both tanks just filled but it hasn't be hot here. Purge or bad regulator? Left both tanks full open to let them purge.
SOFI Member
Over59 is offline   Reply With Quote
Old 09-03-2009, 04:16 PM   #2
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
I've never had a regulator do that. I'm thinking a bad regulator and you're wasting your propane.
Chris
Minno is online now   Reply With Quote
Old 09-03-2009, 08:23 PM   #3
Over59's Avatar
1968 17' Caravel
Images: 37
Put on the back up regulator and seems fine. You do carry a backup regulator dont' you.
I'll send it to ASC for inspection as this is wierd.
SOFI Member
water pressure regulator leak. kss Plumbing - Systems & Fixtures 1 01-15-2009 10:25 PM
Dual LP Tank Regulator Steve & Susan LP Gas, Piping, Tanks & Regulators 10 04-25-2008 03:37 AM
Propane tank, lines, regulator question Lothlorian LP Gas, Piping, Tanks & Regulators 16 02-27-2008 10:02 PM
New LP gas tank - no purge - blues flitzwhopper LP Gas, Piping, Tanks & Regulators 5 07-10-2006 06:32 PM
LP Regulator leak? 3Ms75Argosy LP Gas, Piping, Tanks & Regulators 5 04-29-2003 09:41 AM
