Old 01-28-2007, 01:33 PM   #1
Send a message via Yahoo to dhe9
regulator issues
hello,
refilled my propane tank and checked with soap. there is a leak where the rubber hose fits on to the brass fitting that goes into the regulator. the hose can be rotated on the fitting so thinking the copper cinch on the hose is lose.
how does one tighten this or replace. looking for suggestions.
thanks,
david
socal
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 01-28-2007, 02:58 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
It's time for a replacement!
It's a common item at any propane/rv store.
Get 2!
Michael
ArtStream is offline   Reply With Quote
Old 01-28-2007, 03:53 PM   #3
regulator
Get 2!
Michael
michael,
thanks for replying. so is the whole hose replaced or just the cinch? just slide on to the brass fitting?
thanks,
david
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
Old 01-28-2007, 05:30 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you are describing what I think, it is a special fitting requiring special equipment. I would take the whole fit and caboodle from the regulator on up to the tank to a dealer to match up. While you are at it have them check out the regulator too. The last for quite a while but not forever
You can check the regulator yourself with a manometer to measure the pressure. This is elementary school science. You can easily make yourself with a loop of clear tubing attached to a board half full off water. One end is hooked to the regulator when you turn the gas on the gas side will drop the open end side rise. The difference should be 11" to 12".
Old 01-28-2007, 05:55 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The only way a crimped fitting can get loose is when the the hose is old and shrinks reducing the clamping pressure. A new hose is good insurance. Check the tank pigtails too.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 01-28-2007, 06:14 PM   #6
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Originally Posted by dhe9
hello,
thanks,
david
socal
You can have the rubber hose replaced at welding supply stores and they will use the same crimp clamp on the new rubber hose. The old hose is shot because of age and shrinkage. Now the bad part - this will cost you more than the cost of buying a pre-assembled hose from a dealer. So, unless you are talking about a fitting that cannot be replaced new - then buy the whole thing new and move on.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
