Old 01-27-2016, 07:55 AM   #29
2016 28' Flying Cloud
The Plains , Ohio
Originally Posted by dznf0g View Post
Well, the leak would have to be in the regulator itself, or downstream to drain both tanks. And you do/can have warnings:
1) odor
2) many of us have tank gauges and/or inside tank gauge monitors.
What sort of gauge do you use. Do you put a gauge on both tanks?
whitegs is offline   Reply With Quote
Old 01-27-2016, 09:38 AM   #30
1998 30' Excella 1000
Livingston , Texas
My rig came from the factory with gauges on both 30 lb tanks. Readable gauge on the tank and a remote read on the panel inside. I guess they don't put them on any more...
Siegmann is offline   Reply With Quote
Old 01-27-2016, 01:29 PM   #31
dznf0g's Avatar
Oswego , Illinois
Ditto, I think it is still standard on Classic....not sure about the rest.
-Rich-
Old 01-27-2016, 01:58 PM   #32
Road Dog's Avatar
2016 30' Classic
Lake Wylie , South Carolina
Here is the recall.
NHTSA Campaign ID: 15V761000
Manufacturer: Airstream, Inc.
Model Year: 2016
Make: AIRSTREAM
Model: CLASSIC
Recall Date: 11/17/2015
Component: EQUIPMENT:RECREATIONAL VEHICLE:LPG LINES AND FITTINGS
Potential # of Units Affected: 904
Summary: Airstream, Inc. (Airstream) is recalling certain model year 2016 Classic, Flying Cloud, International, Sport, Eddie Bauer, and Land Yacht recreational trailers manufactured August 3, 2015, to November 13, 2015, and equipped with Auto Changeover Propane Gas Regulators. Propane gas may leak into the plastic gas level indicator window of the regulator causing it to degrade and crack.
Consequence: If the indicator window cracks, propane gas may leak out, increasing the risk of a fire.
Remedy: Airstream will notify owners, and dealers will replace the propane regulator and the required hoses, free of charge. The manufacturer has not yet provided a notification schedule. Owners may contact Airstream customer service at 1-937-596-6111 extension 7401 or 7411.
Paul and Linda Hardin
WBCCI 21870
2016 Airstream Classic 30'
2015 Ram 2500 Laramie Mega Cab Turbo Diesel 4x4
Vietnam Veteran Army 70 - 71
Road Dog is offline   Reply With Quote
Old 04-26-2016, 07:20 AM   #33
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
interesting!!.. also a good way to check for leaks in the system. If everything is off then the indicator should stay green for a long time. If you turn tanks off and everything is off and indicator goes to red real quick that could mean a leak some where in the system. maybe?
I know some regulators bleed a tiny bit of gas all the time to prevent bellows lock so how long would it take to go red.. I shall see next time at unit.
Yes, it will stay green until pressure is lost in the lines between the yanks and regulator. If you turn on the stove, it will turn red in a couple of minutes.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 05-02-2016, 05:08 PM   #34
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Maiden Voyage with 2015 23' FC FB Propane Regulator Problem
Originally Posted by BASE729 View Post
I have a 2015. The regulator will switch over... But not click red. How did I find that out? When it was 10 degrees in Golden, CO. Kept checking regulator day and night... Green. Then it got REALLY cold in the airstream. Went and lifted both tanks and both were empty.
The red indicator works for me about 25% of the time. Will be getting it replaced when I get home. Don't trust the indicator.
We had the identical problem in northern New Mexico at 30 degrees in late April 2016. AS warranty won't replace until their approved tech checks it out. Closest AS tech is hundreds of miles away. Looks as if I'll need to replace it on my own and fight them for the $$ under the warranty agreement.
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
LP Regulator w/Auto Change Over jreckin LP Gas, Piping, Tanks & Regulators 1 06-30-2015 11:38 AM
Over kill, or just over the top! airjeff Tow Vehicles 12 07-22-2010 09:13 PM
Didn't know there was such a thing as 14.5" rims 59toaster Wheels, Hubs & Bearings 1 05-04-2009 09:23 PM
Honest Officer, I didn't mean to Raptorrider2001 Our Community 12 06-27-2008 11:01 AM
Testing regulator auto switch over Safari Tim LP Gas, Piping, Tanks & Regulators 2 08-01-2004 11:39 PM
