Old 07-28-2019, 09:43 AM   #1
Lakewood , Colorado
Regulator
I recently piped in a duel fuel generator worked great for two trips last weekend would not run off of f propane auxiliary port as it has in the past. Worked fine on gasoline. Hooked up my grill to same port as usual I lite grill and then checked stove inside very low flame. Thoughts.
Itch is offline   Reply With Quote
Old 07-28-2019, 09:48 AM   #2
UncleBad's Avatar
2018 27' Tommy Bahama
Oro Valley , Arizona
Low propane level?
Bad regulator or transfer switch?
Hose issue under the AS?
Hose leak? They do go bad but hope they last longer than 3 years. Any smell?
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 07-28-2019, 10:03 AM   #3
Lakewood , Colorado
Originally Posted by UncleBad View Post
Low propane level?
No smell. Transfer switch? Is it part of the regulator / tank switch over ?
Old 07-28-2019, 06:52 PM   #4
UncleBad's Avatar
Do you have dual propane tanks? The transfer switch sits between then and is used to switch to a full tank.
Old 07-28-2019, 07:55 PM   #5
2017 28' International
Baileys Harbor , Wisconsin
Ok. I’m going to be real low tech. I had the same problem. I took off the connector and found there was a rock that got lodged in it when I forgot to put back the cap. Might want to take the end piece off and just check for any obstruction.
But first make sure your tank is full
Daquenzer is offline   Reply With Quote
Old 08-31-2019, 05:16 PM   #6
2018 22' Sport
San Antonio , Texas
I have a dual fuel Champion generator. It worked fine with propane for two months. Sat idle for a couple of months, then wouldn’t start on propane. Started on gas just fine. I’m thinking my regulator is damaged. Any thoughts.
CinTerLine is offline   Reply With Quote
Old 09-01-2019, 05:25 PM   #7
UncleBad's Avatar
Anything is possible. Did the regulator get damaged?
Which regulator are you using?
Double check you did t run out of propane and double check the starting procedure your using since you have not used it for two months...
Old 11-08-2019, 10:43 AM   #8
2018 22' Sport
San Antonio , Texas
Turns out it was a damaged regulator. Champion replaced under warranty. Have since purchased backup regulator for redundancy as well as backup battery. Very happy with Champion service.
Old 11-08-2019, 03:50 PM   #9
2017 16' Sport
Canyon Country , California
I had similar problem until I realized that I had to take off the regulator hooked to the grill and bought a long propane hose and hooked to the grill. Solved it.
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
LP Regulator PatCrusse LP Gas, Piping, Tanks & Regulators 27 05-15-2004 02:22 AM
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 08:08 AM
Dual Fuel Gas regulator thenewkid64 LP Gas, Piping, Tanks & Regulators 5 03-12-2003 03:26 PM
Grand Hall Ent. gas regulator recall 53flyingcloud LP Gas, Piping, Tanks & Regulators 0 12-23-2002 08:29 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 08:26 PM
