Join Airstream Forums Today
Old 01-02-2012, 06:41 AM   #1
gainesville , Florida
Refrigerator check lite on gas
hi,
i'm new to rv's and my 2008 airstream refrigerator wont seem to go into gas mode. it keeps getting a check lite. i smell gas at the outside access panel. i've checked the fuses and they are good. any ideas. also is it ok to smell gas at all when you open the access panel? thanx
stuartkaye is offline   Reply With Quote
Old 01-02-2012, 06:48 AM   #2
Aviator's Avatar
1997 34' Limited
South of Atlanta , Georgia
Our check light comes on if we haven't used it for some time. I find lighting the cook top pulls gas into the lines, then the fridge works fine.
I don't think you should smell gas at the panel. That indicates you either have a leak, or you have enough gas in the lines (referencing the first paragraph) which isn't igniting. This means you may have an ignition problem.
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Aviator is offline   Reply With Quote
Old 01-02-2012, 06:52 AM   #3
yes, that kind of confirms i might have an ignition problem. i'll lite the cooktop and check any way. thank you very much. if that fixes it i'll let you know.
stuart
Old 01-02-2012, 07:00 AM   #4
RLS
RLS's Avatar
2004 25' Classic
Longwood , Florida
It does take a few tries sometimes after not being used for awhile. I turn the gas on and wait a few minutes before turning the fridge on. Also, you can go out to the access door right after turning it on and hear if it is trying to light buy hearing it sparking.
Julia & Bob
W/ Neka & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 01-02-2012, 07:06 AM   #5
Well Preserved
overlander63's Avatar
Colfax , North Carolina
When you try to use LP mode, you should be able to hear the igniter clicking for a few seconds to a minute after you switch it on. If you can't, you may have a bad board, bad igniter, or even a blown fuse on the board. If you hear the igniter, but get no flame, you could have a blockage in the burner assembly. That would give you the gas smell, but no flame. A blockage could be a spider or mud dauber nest in the line or burner.
Some days, it's just not worth chewing through the restraints.
Old 01-02-2012, 07:10 AM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
Siloam Springs , Arkansas
Running out of propane can cause this. If the tank runs out, there is a short period of time that propane is still flowing, but not at a sufficient rate to burn in the burner. The refer will allow this final puff a gas to flow and try to light. You will smell gas, and the refer will say "check".
The advice to light a burner on the range and the water heater is good Just switch the to the full bottle first. This will allow propane to flow throughout the plumbing.
I have been fooled by the auto change-over on the propane tanks before. I didn't know it had switched and burned both tanks. Make sure you have propane.
Good Luck,
Jeff & Cindy
Remi & Hunter
'09 27FB Flying Cloud
WBCCI #7026 Air #17054
"Fus-A-Lodge II"
jdalrymple is online now   Reply With Quote
Old 01-02-2012, 07:11 AM   #7
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by stuartkaye
... also is it ok to smell gas at all when you open the access panel? thanx
NO!
Make up a solution of soapy water, something like Dawn works okay. Apply it to the fittings on the copper gas line going to the burner, and look for bubbles indicating a leak. I suspect a different problem. The check light comes on when the electronics have attempted to open the gas valve and started ignition, but didn't detect a flame. This may be something as simple as a spider nest in the burner tube. You may have to temporarily remove a heat shield to get better access to inspect the burner tube and clean it out as needed. If the spark electrode got moved somehow or its wire disconnected, it would also fail to light.
The electronics board could be faulty also and most RV techs have a tool to test it.
There should be a user manual that came with the fridge that has a troubleshooting section and details as to cleaning, electrode position, etc.
Be sure to shut off the gas and power before working in there.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 01-02-2012, 07:16 AM   #8
lite the range then the refrig and seems to be working fine. thanks for everyones help.
I think this time you saved me some money and a trip to the rv service center.
Old 01-02-2012, 07:29 AM   #9
Gas burners on refrigerators sometimes need cleaning. On my 2004 Safari the burner needed replacing. It got very difficult to light as a result.
I had the repair shop do the work because I don't like to work on gas appliances.
If it is cold, it may take a couple of tries to light a refrigerator in good repair. If the trailer runs completely out of propane, the airlock must be purged before the refrigerator will light. I purge the airlock by running the stove and making a few tries to light the refrigerator. Warm up a cold refrigerator by running it on electricity. Refrigeration occurs by heating up ammonia with an electric heater. After the heater runs a while, the refrigerator should easily light on gas.
When the refrigerator tries to light, a little gas is discharged. If it doesn't fire, the gas isn't burned and smells. There isn't enough gas to cause an explosion and is not in itself indicative of a malfunction.
handn is offline   Reply With Quote
No gas setting on dial? Northlander Refrigerators 2 11-20-2011 10:32 AM
Gas Oven to Replace Convection/Microwave 10Smiles Stoves, Ovens & Microwaves 7 08-26-2011 08:52 PM
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Got gas? ROBERTSUNRUS Off Topic Forum 13 06-25-2011 12:14 AM
