Old 04-02-2014, 04:04 PM   #1
2016 30' Classic
Erie , Colorado
Reducing wear and tear on Propane Tank and Storage plate
Here's something I did to my new propane tanks. When I was flying hot air balloons we used to do this to the larger 10 gallon tanks we flew. It helped protect the floors more than the bottom ring on the tank.
Basically take a piece of tubing, can really be just about any type including a piece of old garden hose. Cut a slit in it and place over the tank bottom ring edge.
Should help reduce the wear and eventual rusting of the mounting plate.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 04-02-2014, 04:30 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Great idea. I've been spraying some Boeshield T9 anti-corrosive there each time I refill a tank. It's a little messy inside there, the paint wears in a circle, but there is no corrosion. I think I'll try this with tubing.
Doug and Cheryl
Old 06-10-2014, 07:08 AM   #3
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
What a great idea! We'll have to try this after we figure out our new regulator configuration!
Rhino33 is offline   Reply With Quote
Old 06-16-2014, 06:14 PM   #4
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Kind of off subject but does anyone know about how much propane the refrigerator uses? As when boon docking.
TinCan
graysailor is offline   Reply With Quote
Reducing Honda 2000 Generator Noise nsbcpa Generators & Solar Power 9 08-14-2013 06:13 PM
Belly Pan Wear & Tear TinLoaf Belly Pans & Banana Wraps 4 03-06-2012 12:34 PM
What is missing? weight reducing. qc1500 Hitches, Couplers & Balls 5 04-19-2011 01:16 PM
Propane tank storage flmgrip Electrical - Systems, Generators, Batteries & Solar 7 02-25-2010 02:22 PM
Reducing Tongue Weight by Loading Rear of AS FranzB Towing, Tow Vehicles & Hitches 20 11-11-2006 12:37 PM
