Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 02-12-2016, 05:57 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Red Smelly Liquid in Propane Lines
I am bringing up a new (to us) trailer. Several projects are in the works. On the propane side, the water heater is weird (see post in plumbing). I am adding a quick disconnect for a grill. In the process I disconnected the rubber feed hose from the main copper line and an ounce or so of really smelly red liquid came out. My working theory is it is compressor oil from a propane fill station that absorbed whatever the stinky stuff is that they put in propane. It had the appearance and feel of hydraulic fluid but smelled really bad.
Anything I should be concerned about?
Al
Old 02-12-2016, 06:17 PM   #2
2015 16' Sport
Pineola , North Carolina
I have seen this on a camper before. I suspect you are correct and it is a concentrated form of the chemical added for smell. Not sure what to do except drain it out. Let us know what you find out.
"Certainty on any matter is not one of the human attitudes the Gods admire or tolerate."
A. Cross
D Greene is offline   Reply With Quote
Old 02-12-2016, 06:22 PM   #3
dznf0g's Avatar
Oswego , Illinois
There are oils which precipitate out of propane and over time will accumulate in low spots in the lines. I am not sure if it is part of the petroleum or the odorizor, but it is common in older units.
-Rich-
Old 02-12-2016, 06:47 PM   #4
1998 30' Excella 1000
Livingston , Texas
I've read it described as in post #2 & #3 above. Also heard that those liquids can leach out compounds from the flex hose below the tanks. In the worst case, they can block the flow enough to reduce the gas pressure at your appliances. Good to drain it.
Siegmann is offline   Reply With Quote
Old 02-13-2016, 02:22 PM   #5
Box Elder (formerly Long Island, NY) , South Dakota
RVGeeks did a YouTube video re: winter camping. I was not aware that at winter temperatures, particularly when using an extension hose, oil can "settle" out from the gaseous propane. It would be wise for you to consult a propane specialist.
NY24 is offline   Reply With Quote
Old 02-23-2016, 03:57 PM   #6
2018 30' Classic
Mannford , Oklahoma
Our 2016 23FB was on its first trip last week and the propane quit flowing to the appliances. Had a LPG vendor check the system. Oil of some kind was in either the propane or the tanks and it fouled the regulators. The dealer who filled the tanks when the rig was bought said his propane was OK, so the tanks must have come from A/S with the oil in them. Had to purge the tanks of LPG, fill up with fresh propane and install new regulators. A/S customer service said send them the bill. They did not seem surprised by the oil in the LPG bottles.
geraldsmith is offline   Reply With Quote
Old 02-23-2016, 04:05 PM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Post #6 above makes one wonder what if any QC (quality control) tests were done at the factory or if the dealer even did the PDI (pre-delivery inspection) hands on instead of sitting at a desk.
Old 02-23-2016, 05:05 PM   #8
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
That gooey stuff sometimes gets into a filler's supply tank. It is a by-product of the refining process that usually doesn't wind up in great quantity in the filler's tank and, from there, unintentionally pumped in harmful quantity into a customer's cylinder. Airstream's fault? Nope. Filler's fault? No, not really. Refiner's fault? Probably.
Lynn
ACI Big Red Number 21043
Old 03-03-2016, 01:42 PM   #9
1989 32' Excella
Sharon Springs , New York
I'm also looking at replacing the LP tank regulator and rubber lines on my Excella 1000 and expect to see some liquid deposits draining from the hard line under the trailer, can this line be cleaned/flushed to get all the residue out? My other options include to either replace the copper line as well as the rubber lines or just drain out what I can and reconnect the original copper line to new rubber lines. Any suggestions would be appreciated... Thanks...
JDB
MAJORJDB is offline   Reply With Quote
Old 03-03-2016, 02:11 PM   #10
In retrospect I probably only got a tablespoon or two out of my 2002. It seemed to be in the rubber hose between the tanks and the hard line. That may have been the low point in the system; it is also a very low pressure line so I wouldn't think it would migrate very far, except for gravity flow. When I disconnected the union from the hard line, nothing came out.
You could maybe just disconnect the appliance lines at the other end and blow it out with compressed air if you are concerned. I don't have a clue as to an appropriate solvent to flush with. Mine had the consistency of hydraulic fluid.
Al
Old 03-03-2016, 04:36 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The oil is an added odorant. It is added by law. It contains mercaptain , the smelly part
Old 03-03-2016, 06:55 PM   #12
1985 31' Sovereign
Lovettsville , Virginia
This is partially correct.
Mercaptan is the odorant that is required to be added to consumer grade propane. Propane itself is odorless, so the odorant is added to ensure a leak can be detected by smell (as a precaution). Mercaptan itself is a colorless gas, not a liquid.
Although it is entirely possible that a liquid may have absorbed some of the smell, the liquid itself would not be mercaptan, nor would it be propane in a normal temperature and at normal atmospheric pressure.
This sounds like some sort of contaminant has found it's way into your system; likely from a fill station with quality control or supply issues. I would recommend having the system purged (with nitrogen) and refilled. Hope you get it all sorted out without much expense!
85 Sovereign is offline   Reply With Quote
Old 03-04-2016, 08:34 AM   #13
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
At the consumer level, oil, containing the odorant is added to the odorless log gas.
The accumulated oil in the low part of the lines is that accumulated oil, we all have it depending on the amount of gas sent through the lines.
I drain mine once a year.
Old 03-08-2017, 02:09 PM   #14
Boxite's Avatar
2008 22' Safari
Liquified Petroleum Gas.... it's made from petroleum. A mist of oil is sometimes precipitated out inside storage tanks and supply lines.
Blow it out with compressed air or flood the lines with alcohol and then blow it out.
It's rare that sufficient quantities accumulate to actually cause trouble and most users never know it.
Liquid Glass rebel beck Cleaning, Stripping & Polishing 24 06-01-2018 11:46 AM
Liquid Stainless Steel? Hank A General Interior Topics 49 07-29-2012 10:29 AM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
Liquid stainless steel paint adonh General Interior Topics 2 10-10-2009 03:08 AM
The effect of using the blue liquid black water treatment on septic fields wacnstac Waste Systems, Tanks & Totes 6 06-01-2006 09:21 PM
