02-01-2007, 11:27 AM
#21
1967 22' Safari
MILAN
Bump
I thought that this was important for others and newbies to read... Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
02-01-2007, 11:43 AM
#22
1963 19' Globetrotter
Laguna Beach
Very Good information...Thanks, I'm a single woman new airstream owner and not usually the best at checking for safety items and precautions. I do read some of these posts as well as the interior decorating ones, so I am very grateful when I happen to open up a post so enlightening and potentially life saving.
Thanks again, Debra
02-01-2007, 11:59 AM
#23
1965 26' Overlander
xxxxxxx
, Oregon
Yes we also use a t-bar and a length of all-thread. we can really crank them down tight with that. Lets not forget to INPSECT at every stop! And Never roll with any pilotlights on.I've seen more than one melted RV on the side of the road!
02-01-2007, 01:29 PM
#24
1993 34' Excella
Estancia
, New Mexico
Watch the turning radius
I was trying to manuver into a dump station and made a too tight turn hitting one of the tanks with my bumper. No significant damage to the tanks but the aluminum hold down cross piece snapped like a twig.
06-18-2007, 04:32 PM
#25
1958 26' Overlander
Mesa
Bump
An important message that everyone needs to read
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
06-18-2007, 05:37 PM
#26
GLASS GODDESS
2011 22' Sport
Greenville
, South Carolina
Wow, thanks for the info.....I'm going to find away to have a back-up system in case one fails the other one can compensate.
06-18-2007, 11:18 PM
#27
1989 25' Excella
Portland
, Oregon
Tie downs
It's easy to see that extra tie downs are important.
Is there any info on the LP gas on the master panel always reading full?
06-19-2007, 05:54 AM
#28
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Originally Posted by JStanley
‘Remove Tanks In Case of Fire’ is another issue. So I’ll get a bigger fire extinguisher to keep in the tow vehicle.
Although LP tanks can and do rupture and explode in very hot fires, they frequently are the only things that survive a fire intact. It takes a pretty hot fire to rupture an LP tank. You seldom see that kind of heat at the bottom of a travel trailer fire or at the tongue. A fire extinguisher is NOT going to keep them from getting hot, and if your trailer is burning to the point that you think that the LP tanks are going to be involved, removing the LP tanks is probably not the best use of your time. Turn them off if you can do it safely... and then spend the rest of your time getting as far away from the trailer as you can!
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
06-20-2007, 12:28 AM
#29
Battle Ground
My wife is afraid of propane so we always turn off the gas when traveling. We put the refer items in an ice chest for traveling.
I will check our tank rod.
Thanks for the warning.
06-20-2007, 05:58 AM
#30
Silver Mist
Riverhead
, New York
A marine supplier sells Stainless Steel threaded rods in 3' lengths for >$5
That would be a good fix put two nuts on the bottom with Locktite, and it should hold forever.
06-21-2007, 10:23 AM
#31
1978 24' Argosy 24
Woodinville
Why not just put a block of ice in the refer? It makes a dandy ice chest . I keep a 1/2 gallon plastic jug frozen just for this. It helps get the fridge down to temp initially and then I transfer it from the freezer to the refer when I can't run the fridge. Of course if you want to keep the freezer compartment cold the stuff in there acts as "ice" and it'll stay frozen quite a while as long as you don't open it. If there's not much in the freezer then freeze another bottle of water so you have more mass to keep it cold. A full freezer will stay cold the longest. -Bernie
06-22-2007, 03:02 PM
#32
1977 31' Sovereign
This same thing happened to me a couple of years ago on my '77 Sovereign...at 70 mph on an Interstate.
I didn't hear anything unusual, over the sound of the Cummins anyway, but happened to notice a strange white cloud in my passenger side mirror billowing out from the front of the trailer.
I had no idea what had happened until I got stopped and heard the rushing sound of gas. The cotter pin had sheared off the bottom of the original hold down rod, and both tanks were under the trailer....still connected with the hoses, but both had big holes rubbed in them.
The lucky part of this is that these were the original aluminum tanks for this trailer, and, being aluminum, created no sparks while dragging down the road.
I can't imagine the result if there had been a spark.
If, for no other reason, I am now a firm believer in aluminum tanks........
06-23-2007, 08:46 PM
#33
1973 Argosy 26
Bemus Point
, New York
Same Experience
I had the same tension rod failure outside Indianapolis in 1992 on my 73 Argosy 26. Both tanks were dragging underneath the trailer. Before I could find a pull out area (single lane construction area) one had worn through the hose and rolled out the back where a Semi hit it breaking off the valve and turning the tank into a missle. No one was hurt and no other damage occured thank God. I now use ALL the above mentioned safety ideas including an oversized stainless steel threaded rod with a sleeve over most of its length.
I would never travel with the valves open. This was about the most frightening experience I can imagine.
06-25-2007, 09:21 AM
#34
Central
, Mississippi
I had the same thing happen, strange clinking/dragging sound. It was my own stupid mistake. I didn't have one of the bottles over the little tab on the lower mount.
07-20-2007, 01:46 PM
#35
1958 26' Overlander
Mesa
Bumped for its importance.
1958 Overlander
4CU 1st VP
07-20-2007, 02:53 PM
#36
Central
, Mississippi
What's that funny dragging sound???
07-20-2007, 05:00 PM
#37
2005 28' Safari S/O
Paradise
Originally Posted by wahoonc
If the tank valves had been open the OPD mechanism would have kicked in and shut the flow off, it is part of what they are designed to do....that is if you have the properly upgraded valves.
Good point Aaron. In fact, you can disconnect the hose with the valve open and the OPD will shut of the flow.
Steve
"THE OLDER I GET, THE BETTER I WAS"
07-20-2007, 06:00 PM
#38
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
And all this time I thought my plan to replace that rod with stainless steel just to get rid of the rust was excessive. It has suddenly leaped several steps up the list.
Vaughan
06-05-2008, 12:38 PM
#39
Another disaster avoided!
While buffing my trailer tongue down I discovered that my propane hold down post was almost rusted in half. The socket was also severely rusted and thin. I decided to grind it all off and start over.
I used mild steel rod for the post. I have read where others had obtained hardened all thread rod. My experience has been that sometimes the harder bolts tend to break before they bend. In this application a bent rod would be better than a broken one. I threaded one end with a standard 1" hex die nut.
I found that 1/2" schedule 80 pipe fits the 1/2" smooth rod nicely. I actually used a schedule 80 black nipple. I drilled a 3/16 hole through it and the rod at one time using a drill press. I have temporarlly attached the nipple to the frame with a 3/16" machine bolt to hold it while welding.
06-09-2008, 06:31 AM
#40
1958 26' Overlander
Mesa
Nice, Vernon
Looks like that will work well.
1958 Overlander
4CU 1st VP
