Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 05-05-2016, 12:54 PM   #101
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
I drilled the wing nut for a padlock so it can not unwind in the enclosure on the Classic and the 23D International Serenity
Old 06-25-2016, 11:10 AM   #102
1988 34' Excella
Stanardsville , Virginia
Thanks for sharing this, anytime I learn about a different safety check I'm ahead of the game!
madpiper is offline   Reply With Quote
Old 08-21-2016, 01:54 PM   #103
Boxite's Avatar
2008 22' Safari
On my newer 2008 the tanks are sitting not on an open-loop-base... but on an oval pan...which was originally secured by A/S to the A-frame with only two, cheap screws that vibration had completely cut/shattered. The tank brackets were held to that pan with a long all-thread drilled thru the base of the pan and a wingnut, ...covered with that cheap, plastic Camco cover.
Therefore the tanks were sitting on a pan which was totally unsecured to the trailer frame except by their own weight and held in place by the hoses.
I cleaned it all up, repainted and drilled/bolted the pan to the frame, and installed new all-thread covered with steel tube which freely rotates about the all-thread (to discourage any hacksaw-equipped thief.)
A long-shackle bicycle lock drilled thru the upper bracket prevents the wingnut from being unscrewed by same thief.
I think the old-style "bucket-brackets" for a base is an excellent idea and I may make my own and weld them to that oval pan. I've seen some in the PPL catalog.
This is an excellent discussion and I posted this msg to bump it back up.
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
Horrific Disaster Averted! Pick Waste Systems, Tanks & Totes 7 05-06-2004 10:55 PM
Twister Fifties Trailer John Our Community 8 12-01-2002 08:44 AM
Disaster Weekend davidz71 Our Community 11 07-03-2002 04:27 PM
