Old 09-01-2009, 12:27 AM   #71
Ottawa , ON
The service manual says to use a 3/16" drift punch rearwards on the pin, while holding a heavy bar or hammer against the ring above the pin.
Old 09-02-2009, 11:09 PM   #72
4slice
4slice's Avatar
1977 31' Sovereign
Chase , British Columbia
removing pin
You can also use an angle grinder on the pin--very quick removal!
4slice is offline   Reply With Quote
Old 09-13-2009, 07:18 PM   #73
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
The thought of dragging my tanks was just too much for me and because of this thread I made the change this weekend. Went to Home Depot and bought the shaft and assorted hardware and began the work. My old shaft was held in place by a screw and nut, it was the by product of moving the shaft higher when I switched to aluminum tanks (they are a little taller then the steel ones). It was a quick and simple change over.
ID:	87147   Click image for larger version
Richard
Old 03-18-2010, 10:58 AM   #74
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Richard,
I'll have to take a look at this at next months Rally. I saw the threaded rods at Home Depot last week and it got me thinking again about this changeover.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-18-2010, 12:10 PM   #75
VIKING's Avatar
Boulder Creek , California
This is the exact thing I did last year. Stainless allthread with two nuts above the holding bracket, and two below it to lock the rod in place. It's a really simple fix. Someone added a plastic tube or length of hose to the allthread on one of these and it looked great. I'm thinking of adding a length of aluminum tubing to cover the threads on mine, that I could polish along with the tanks.
Sweet!
Rich the Viking
VIKING is offline   Reply With Quote
Old 03-18-2010, 12:30 PM   #76
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Sweet!
Rich the Viking
Rich,
Did the top wing fasteners (whatever you call them) fit exactly on the threads?
1958 Overlander
4CU 1st VP
Old 03-19-2010, 02:26 PM   #77
VIKING's Avatar
I have a steel wingnut on mine, so I brought it to the hardware store with me to find a compatible stainless allthread piece. I believe they all use standard threads but there are a lot of different wingnuts and brackets, some steel and some aluminum. You might be able to see it in this picture if you enlarge it.
Rich the Viking
Name:	'64 SAFARI 018.jpg
Old 03-19-2010, 05:11 PM   #78
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Rich the Viking
Thanks, Rich. Mine's pretty much the same. That's a good idea. I'll just take the top wingnut with me.
1958 Overlander
4CU 1st VP
Old 03-19-2010, 06:19 PM   #79
VIKING's Avatar
I think you'll like this conversion Mello Mike.
When I got my new #30 tanks I went to remove the old ones, which were shorter. I gave the wingnut a VERY half-hearted twist with ONE hand(thinking I was wasting my time and would need a wrench and some 3-in-1 oil) and the whole rod, regulator and hold-down came off in my hand, and I was barely able to keep the tanks from falling on the ground. The drift pin was nothing but a faint memory and dark stain on the rod. It's a miracle I didn't have a "disaster thread of my own to start.
Rich the Viking
P. S. Mike, you look like a dead-ringer for a young James Garner. Amazing!
Old 03-28-2010, 05:19 AM   #80
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I installed a new threaded rod for the holding tanks this last week. I spent about 13 bucks for the rod and a few more bucks for the washers and bolts at Home Depot. A very quick and easy modification. Well worth it.
1958 Overlander
4CU 1st VP
Old 04-07-2010, 06:23 PM   #81
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Mike, Our trailer is not here and I am changing from 20lb LP tanks to 30lb LP tanks tomorow (in the rain it looks like) and I want to change to the new thredded rod. I want to take all the hardware with me when I go. SO my question is. What size Thredded rod did it take? How long? We too have the aluminum wing nut handle.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 04-07-2010, 09:16 PM   #82
VIKING's Avatar
I just checked mine, which is shown in a picture in a earlier post. It is a 36" length of 1/2" stainless steel allthread. It hangs down 5" below the bottom locking nut. I would have cut it off, but I had something else to do that month. You ever tried cutting a 1/2" stainless rod? No thanks.
It does'nt hang as low as the jack does anyway, so I don't mind it.
Rich the Viking
Old 04-07-2010, 09:47 PM   #83
Elkhart , Indiana
Thanks Rich. I will be able to get the parts on my way instead of back tracking.
I will take the Roto zip with the cut-off wheel if I think it is too long.
I like the newer tank covers and may just leave it long and see if we get one of them and use it to secure the cover as well. But that is another season away.
Thanks again.
Mike
Have a great day!
Old 08-15-2010, 08:21 AM   #84
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Mike,
Did you ever do this modification?
1958 Overlander
4CU 1st VP
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 12:34 PM
Horrific Disaster Averted! Pick Waste Systems, Tanks & Totes 7 05-06-2004 11:55 PM
Twister Fifties Trailer John Our Community 8 12-01-2002 09:44 AM
Disaster Weekend davidz71 Our Community 11 07-03-2002 05:27 PM
