Old 08-11-2009, 09:57 PM   #57
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Wow,
Glad it turned out okay minus a little damage. Think I'll start looking for a new tie down rod! I never took into account fatigue it suffers through the years.
Really appreciate the heads up....
Alwhisman is offline   Reply With Quote
Old 08-12-2009, 01:10 AM   #58
Mexray's Avatar
1978 28' Ambassador
Morada , California
Thanks for the 'heads up' on this weak point...I've always looked at that rod with the hole for the lower pin, wondering if that thing could fail...now I know!
I updated our tank valves, and had them tested just after we bought our AS last year...
I believe that once the hose fitting is screwed into the tank, gas will flow from a ruptured hose unabated - except if the tank were in an upside down position and the internal float valve were to shut off the flow...indeed a scary sight if you were to see clouds of propane wafting around your AS in the rear view mirror!
We always run our fridge on propane when we're on the road (turning it off for TV refueling operations)...never given a thought about a tank mount failure...let's not let the DOT know of these weakness', or we'll all be 'grounded' and restricted from driving through tunnels and across bridges...
I plan to make some back-up hold-downs ASAP - even some kind of ratchet-down load straps might be in order to give one peace of mind!
Ray & Pat; Morada, CA
Old 08-12-2009, 07:07 AM   #59
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
It's funny this thread got resurrected again. I inspected my hold down mechanism again this past weekend and found that my retainer screw had a nice u-shaped notch in it. No telling how long that would have lasted so I replaced it. I need to find something stronger than a stainless steel screw that will work with this application.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-12-2009, 10:47 AM   #60
VIKING's Avatar
Boulder Creek , California
Mike, I used the 1/2" stainless all-thread with two stainless nuts locked together at the bottom and top of the tube it goes through. This will never come off. I recommend it highly.
Thanks for starting this thread. A lot of people have gotten good info here.
Rich
VIKING is offline   Reply With Quote
Old 08-12-2009, 06:30 PM   #61
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Rich
Rich, did you buy this at a typical RV parts store? I've seen these but thought they were too large to fit in the cylinder mount.
Thanks for the tip.
Mike
1958 Overlander
4CU 1st VP
Old 08-13-2009, 07:48 AM   #62
1992 34' Excella
riverhead , New York
Propane tank hold down failures
Hey Buds,
From my experience it seems most (not all) failures are a direct result of over tightening. Whether it shears the rolled pin or damages the aluminum hold down clamp.
If you have a newer trailer with the propane tanks enclosed it becomes less necessary to "CLAMP" them down. They just need to be HELD down.
With regards to the failure of a propane hose, it is my understanding that the newer now required OPD valves would close off the supply of propane in the event of a hose failure.
Of course none of us want to experience anything like that, but it is good to know that "shutoff" is built into that part of the safety system.
While traveling we sometimes run our refrigerator on electric. And, sometimes on gas. We have solar panels and an inverter that enable us to do this.
Keep up the topic. It is an important one.
Joe
Joe Colao 50th Anniversary President of Metro NY WBCCI # 30916
KC2RAR
joecolao is offline   Reply With Quote
Old 08-13-2009, 10:09 AM   #63
VIKING's Avatar
I got all I needed for my hold-down at Ace hardware. It's just a piece of stainless all-thread and four stainless nuts. I used the original stamped steel hold -down at the top. 1/2" all-thread had the same threads as the original rod.
Rich
Old 08-16-2009, 02:43 PM   #64
84Sovereign's Avatar
1984 27' Sovereign
Escondido , California
Fixed mine this weekend!
I could not find a replacement aluminum hold-down piece so I made my own. I started with a section of 1-1/2" square aluminum tubing that I got from a welder buddy of mine. It is some type of strong alloy, but I cannot remember the alloy type/number. I cut it to 10" long and milled curved slots through the bottom to match the radius of the propane cylinders. I rounded the ends slightly and gave it a few passes on my bench beltsander to match the finish of the factory cast wing nut. My 1/2" threaded rod is attached via a threaded rod coupling welded to the frame. I measured things so that the rod threads pass all the way through the rod coupling and also the wing nut at the top. The end result is not a pretty as it was with the factory cast hold-down piece, but it is much stronger and my tanks are very stable up there.
Cheers,
Chris
Escondido, CA
ID:	85458   Click image for larger version
ID:	85460   Click image for larger version
84Sovereign is offline   Reply With Quote
Old 08-16-2009, 02:55 PM   #65
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Originally Posted by 65GT View Post
If you've got bright shiny polished tanks you might want to opt for brand new OLD style hoses. It will help keep hapless thieves honest. Impulsive thieves are less likely to have a wrench in their pocket...
__
That is good idea!
What about travel with charged tanks?
Y'all would dump gas before travel?
I'm not going to do that, but wondered if this is standard for TT
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 08-16-2009, 04:20 PM   #66
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Mike, I used the 1/2" stainless all-thread with two stainless nuts locked together at the bottom and top of the tube it goes through. This will never come off. I recommend it highly. Thanks for starting this thread. A lot of people have gotten good info here. Rich
Hi Rich:
I have the same set up as you, but for a slightly cleaner appearance slid a piece of cut-to-length 1/2" inside diameter clear plastic hose over the all-thread rod. I also put my old inverted U crank-down holder through the round holes on the top collar of the propane tank instead of just fitting its inverted V-notch over the top of the collar, in the belief if it ever loosens up the tanks will rattle around on the trailer a bit longer with the hold down inside the collar holes than with it loose on the collar top. But I really like the idea pictured earlier of a padlock through the tightening handle to both prevent it from loosening and to discourage casual tank theft.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 08-17-2009, 03:57 AM   #67
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
In addition to the potential for the crossbar to crack (because it is made from high strength but low elongation high silicone alloy), the tanks can come off the trailer because they wiggle loose and rotate to the open section of the handle. To prevent this, I devised this retainer system that positively interlocks between the hold down and the holes in the tank handle. It is easily made from parts at a hardware store or a farm store. It can also be used with the Cast Aluminum bracket.
Old 08-17-2009, 04:15 PM   #68
VIKING's Avatar
Hi Fred, Good day to you! Thanks for the idea of the clear hose over the all-thread. It's a definite improvement in looks and the threads won't catch so much dust and dirt. Great idea! I'll look into putting the hold down through the handles too.
Rich
Old 08-18-2009, 01:23 AM   #69
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
For newer trailers.
Hi, I was always fighting my propane tank cover and propane tanks to stay secured properly. Who's brilliant idea was it to have the wing nut hold the tanks and cover in place at once? Either the tanks were loose and the cover was tight, or the cover was loose and the tanks tight.
My fix was to first allow the tanks to use the same notch on both sides of the hold down bracket. [was second notch on one side and third notch on other side] From the factory, this couldn't be done because of the regulator bracket was a bit too wide. I cut the bottom of the bracket on an angle, on each side, to fit better between my tanks. My next step was to drop the the notched bracket down between the handles instead of on the top of the tanks. This made the tanks sit tightly in place, in addition to using a connector nut to hold the tank bracket down tight. Now my tanks are mounted in place tightly and won't work loose. Lastly I made a sleeve out of copper tubing to take up the added space between the hold down bar and the tank cover. With a body washer on top, under the wing nut, I can now tighten the tank cover properly. Note: I drilled holes in the wing nut and the tank bracket for a pin or lock, but never used it yet.
Name:	My Picture CD 439 (Large).jpg
ID:	85601   Click image for larger version
Name:	My Picture CD 438 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-31-2009, 10:47 PM   #70
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
I read the above accounts of broken hold down rods for the tanks. I bought the allthread to replace the original 32 year old rod. There is a single pin that secures the original rod to the frame cross piece. I cannot drill the pin out. It is harder than the carbide drill bits. I hammered it to see if it would dislodge but it did not move. Any tips on how to remove the pin so I can install the allthread?
Eagle & Bear is offline   Reply With Quote
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 12:34 PM
Horrific Disaster Averted! Pick Waste Systems, Tanks & Totes 7 05-06-2004 11:55 PM
Twister Fifties Trailer John Our Community 8 12-01-2002 09:44 AM
Disaster Weekend davidz71 Our Community 11 07-03-2002 05:27 PM
