Old 06-20-2007, 01:28 AM   #29
Hippo's Avatar
Battle Ground , Washington
My wife is afraid of propane so we always turn off the gas when traveling. We put the refer items in an ice chest for traveling.
I will check our tank rod.
Thanks for the warning.
Hippo is offline   Reply With Quote
Old 06-20-2007, 06:58 AM   #30
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
A marine supplier sells Stainless Steel threaded rods in 3' lengths for >$5
That would be a good fix put two nuts on the bottom with Locktite, and it should hold forever.
'77 Sovereign Intl 31' CB
Old 06-21-2007, 11:23 AM   #31
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Why not just put a block of ice in the refer? It makes a dandy ice chest . I keep a 1/2 gallon plastic jug frozen just for this. It helps get the fridge down to temp initially and then I transfer it from the freezer to the refer when I can't run the fridge. Of course if you want to keep the freezer compartment cold the stuff in there acts as "ice" and it'll stay frozen quite a while as long as you don't open it. If there's not much in the freezer then freeze another bottle of water so you have more mass to keep it cold. A full freezer will stay cold the longest. -Bernie
bhayden is offline   Reply With Quote
Old 06-22-2007, 04:02 PM   #32
JohnGalt48's Avatar
1977 31' Sovereign
This same thing happened to me a couple of years ago on my '77 Sovereign...at 70 mph on an Interstate.
I didn't hear anything unusual, over the sound of the Cummins anyway, but happened to notice a strange white cloud in my passenger side mirror billowing out from the front of the trailer.
I had no idea what had happened until I got stopped and heard the rushing sound of gas. The cotter pin had sheared off the bottom of the original hold down rod, and both tanks were under the trailer....still connected with the hoses, but both had big holes rubbed in them.
The lucky part of this is that these were the original aluminum tanks for this trailer, and, being aluminum, created no sparks while dragging down the road.
I can't imagine the result if there had been a spark.
If, for no other reason, I am now a firm believer in aluminum tanks........
JohnGalt48 is offline   Reply With Quote
Old 06-23-2007, 09:46 PM   #33
1973 Argosy 26
Bemus Point , New York
Same Experience
I had the same tension rod failure outside Indianapolis in 1992 on my 73 Argosy 26. Both tanks were dragging underneath the trailer. Before I could find a pull out area (single lane construction area) one had worn through the hose and rolled out the back where a Semi hit it breaking off the valve and turning the tank into a missle. No one was hurt and no other damage occured thank God. I now use ALL the above mentioned safety ideas including an oversized stainless steel threaded rod with a sleeve over most of its length.
I would never travel with the valves open. This was about the most frightening experience I can imagine.
Aluminutt is offline   Reply With Quote
Old 06-25-2007, 10:21 AM   #34
Central , Mississippi
I had the same thing happen, strange clinking/dragging sound. It was my own stupid mistake. I didn't have one of the bottles over the little tab on the lower mount.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-20-2007, 02:46 PM   #35
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Bumped for its importance.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-20-2007, 03:53 PM   #36
What's that funny dragging sound???
Old 07-20-2007, 06:00 PM   #37
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by wahoonc
If the tank valves had been open the OPD mechanism would have kicked in and shut the flow off, it is part of what they are designed to do....that is if you have the properly upgraded valves.
Good point Aaron. In fact, you can disconnect the hose with the valve open and the OPD will shut of the flow.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 07-20-2007, 07:00 PM   #38
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
And all this time I thought my plan to replace that rod with stainless steel just to get rid of the rust was excessive. It has suddenly leaped several steps up the list.
Vaughan
Old 06-05-2008, 01:38 PM   #39
vhord's Avatar
Images: 96
Another disaster avoided!
While buffing my trailer tongue down I discovered that my propane hold down post was almost rusted in half. The socket was also severely rusted and thin. I decided to grind it all off and start over.
I used mild steel rod for the post. I have read where others had obtained hardened all thread rod. My experience has been that sometimes the harder bolts tend to break before they bend. In this application a bent rod would be better than a broken one. I threaded one end with a standard 1" hex die nut.
I found that 1/2" schedule 80 pipe fits the 1/2" smooth rod nicely. I actually used a schedule 80 black nipple. I drilled a 3/16 hole through it and the rod at one time using a drill press. I have temporarlly attached the nipple to the frame with a 3/16" machine bolt to hold it while welding.
vhord is offline   Reply With Quote
Old 06-09-2008, 07:31 AM   #40
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Nice, Vernon
Looks like that will work well.
1958 Overlander
4CU 1st VP
Old 04-27-2009, 03:40 PM   #41
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Bump
1958 Overlander
4CU 1st VP
Old 04-27-2009, 04:29 PM   #42
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Karma to you!
Good Bump.
I have a new A/S with the aluminum cover - and while my tighten down is different style, I could still envision the tiedown rod snapping - the cover should hold the tanks together, but not necessarily upright! I am repainting under the tanks and around the dual cam set up this weekend. I'll add putting safety straps on the tank to my "to do" list.
Paula
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 12:34 PM
Horrific Disaster Averted! Pick Waste Systems, Tanks & Totes 7 05-06-2004 11:55 PM
Twister Fifties Trailer John Our Community 8 12-01-2002 09:44 AM
Disaster Weekend davidz71 Our Community 11 07-03-2002 05:27 PM
