04-24-2016, 02:10 PM
2015 25' FB Flying Cloud
Meadow Vista
Ran out of propane
Ran out of propane last week , both tanks empty. The valve that switches from one tank to the other must work, but the dial that goes from green to red did not seem to change to red on the last tank. Does anyone have a gauge that works for them?
Thanks!
04-24-2016, 02:19 PM
Princeton
, New Jersey
If you are talking about the indicator on the switch over valve that only indicates when you run out of gas on the first tank to tell you to get more.
2004 Excursion 4x4
04-24-2016, 02:34 PM
Sag Harbor
, New York
Thanks!
Welcome to the forum SilverSinbad!
The indicator valve might be bad. Now that you know how long it took for both tanks to run out, you should have a sense of how long one tank should last on its own. When you get to that stage, try tapping on the indicator window and see if the green and red switch over. I had to do that once or twice. You can also switch the manual handle to the active tank when you confirm that the other has run out.
Or you can simply turn off the full tank, and see how long the first tank takes to empty. That will get you more actively involved with managing the propane supplies -- a good thing when starting out. But obviously this requires a close eye, as the fridge, heat and water heater will go off if not on shore power also.
I have always kept a log book in the trailer to record trip mileage and propane fill-ups. I still have the old log from the 25' AS back in the 90's, and the propane prices are interesting to see. About double now! Keeping the log book -- like manually turning off one propane tank at a time -- has the added advantage of making you more conscious of your propane use.
If you are still under warranty, a new indicator and perhaps transfer valve may be in order.
Good luck!
Peter
04-24-2016, 03:26 PM
Sag Harbor
, New York
PS here is a recent thread with more info:
http://www.airforums.com/forums/f287...er-145711.html
The site's "Search" function works pretty well (above to the right), with the Google search function in the middle of the pop-up box recommended.
04-24-2016, 07:41 PM
2013 30' Flying Cloud
Cincinnati
, Ohio
One tank at at time
Our first season we also ran the propane dry. Of course it ran out on a Sunday morning in Taos, NM. There is no place in Taos to fill propane on a Sunday, at least none we found. But Monday was a good day - we filled propane, did the laundry at the laundromat, and I believe I got a haircut that day too.
Ever since then, I turn on my tanks one at a time, and I keep an orange cord clipped to the tank in use. When I "run out", I always have one full tank. I have never felt the need to get the auto-changeover thing switched, since I think I would keep using the propane "one-tank at a time". Good luck
04-25-2016, 11:02 AM
1967 26' Overlander
Spartanburg
, South Carolina
Some of us old vintage folks are in the habit of pouring a quart of hot water down the side of our tanks every few days to gauge the level in each tank. It works like this, pour the water down one side and quickly feel the tank for the point where the temperature changes. That is the level. My switchover valve is 49 years old and the color indicator no longer works but using the hot water, I can tell which tank is empty if I have forgotten which tank was in use when I filled the empty one. I am a long time proponent of KISS methods.
04-25-2016, 11:23 AM
2019 25' Flying Cloud
Sequim
When you start to shiver in your AS, the eggs don't turn white on your stove, and your partner screams that the shower is cold then both tanks are empty. Simply fill both tanks at once and watch for the same signs when it is time to fill them again. This way you make 50% fewer trips to fill the propane tanks. This is the "KUS" approach - Keep Ultimately Simple.
D2
"Having differences makes a difference"
04-25-2016, 11:26 AM
2015 27' FB International
mesquite
Learn something new everyday.
This was my day!
04-25-2016, 11:38 AM
mesquite
Thanks!
This has nothing to do with the Guage. But just purchased 2 30lb. Aluminum tanks to replace the factory 30lb. Steel tanks. Plan on carrying the old ones in back of pickup as backup if we decide dry camp some day.
Has anyone else done the same with one or two spares?
04-25-2016, 11:40 AM
2012 25' Flying Cloud
Battle Lake
We travel in winter months (South) and use quite a bit of propane. Also considering a propane conversion for the generator if we take it. Running out is a high probability.
So we are thinking of getting a smaller aluminum bottle 10 or 20 lb to carry in the truck bed as a backup, to run the generator on occasion, and to fuel the Weber Q. What do you think?
Doug and Cheryl
04-25-2016, 12:32 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I don't think it's worth the effort to carry extra tanks for spares. It seems, at least to me that is, to be easier to just monitor the levels and fill when one is empty. If you find a supplier that will fill by volume then you can get it filled when you know it's low and don't need to wait until empty. My tanks ( alum twin 40#'ers) are not original so no gauge function but when I suspect one is getting low I take it off and shake it. Guaranteed to work.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
04-25-2016, 12:43 PM
2006 25' Safari
Signal Mountain
, Tennessee
I picked up two of these at Home Depot. They seem to work.
http://www.homedepot.com/p/Nexgrill-...ane+tank+guage
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN,”Greenest State in the Land of the Free”.Davy Crocket
" America is not a place;it's a road." Mark Twain
04-25-2016, 12:56 PM
2013 25' FB Flying Cloud
Mountain Top
, Pennsylvania
Purchase locations for 30 lb aluminum replacement tanks?
04-25-2016, 01:11 PM
1955 22' Safari
Laredo
Vts
Vintage Trailer Supply sells them.
04-25-2016, 03:39 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Originally Posted by moxie t. moto
This has nothing to do with the Gauge... Plan on carrying the old ones in back of pickup as backup...
Yes, I carry spares depending on when and where we are headed. I usually have at least one (#30) for use with the portable propane fire pit we carry. The second tank comes along in the winter months when we know the squirrel cage heater will be getting a workout. It seems the propane dealers are always in the most inaccessible places or closed when the tanks are empty and freezing temperatures are predicted.
Be sure to have a secure mounting method.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
04-25-2016, 03:40 PM
OnTheRoad
2015 30' International
Strasburg
It happened to us also. We determined that it was not the transfer value but the order in which you turned on the propane tanks. The transfer valve has an arrow that displays from which tank one is taking propane. When you first open the propane tank valve you need to turn on the tank that the arrow is pointing at, then turn on the second tank.
Check the transfer valve regularly and when the GREEN indicator turns RED, change the transfer value to the second full tank and then you can fill the empty.
Happy travels.
04-26-2016, 06:04 AM
2006 25' Safari
Signal Mountain
, Tennessee
Happy travels.
Thanks for the great tip, and from a first time poster. Welcome. I look forward to hearing more from you.
Don
'06 Safari 25 LS
