Old 06-22-2016, 04:13 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Foiled Again View Post
But I agree - if you're changing the valves it might make sense to drain the stuff from the bottom of the tank, otherwise, why bother?
Exactly. Especially in an RV, as you drive down the highway the liquid propane gets agitated, which helps keep the odorant from settling to the bottom of your cylinders in the first place.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-23-2016, 01:09 PM   #16
1976 31' Sovereign
Oswego , Illinois
Question puge lp tanks
Originally Posted by NevadaGeo View Post
When you have your tanks recerted, This is where you can get air into the propane tank, or if they find they need to change the valve. Then it takes a couple tanks to get the air out of the propane tank. Your stove will burn orange. Some of the liquid you might find could be from the nasty Odorant they put in the propane so you can smell it. Seems logical that after a few years there could be a bit of liquid from that nasty stuff.
there will not be any air into tank as my lp plant stated aluminum tanks, when recertify only look to see any welds or damage.
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
New LP gas tank - no purge - blues flitzwhopper LP Gas, Piping, Tanks & Regulators 8 01-19-2012 10:31 AM
Regulator leak or tank purge Over59 LP Gas, Piping, Tanks & Regulators 2 09-03-2009 07:23 PM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
