Old 12-15-2004, 03:37 PM   #1
Trailerbunny's Avatar
Angry pullrod stuck open
I recently moved fulltime into my "78 Argosy...but have only slept overnight less than a week total...I kept putting off latrine duty until yesterday...since I was careful to avoid any solids going in...(I forgot that the PO may have left contributions.) TMI
I had to pull very hard on the pull rod to open the valve...but everything gushed out ...things that I do not recall going in...but this part was a success...
The part where I had to push the rod back into place was not...I was afraid to force it since I don't really know the mechanics of it ...when I called my RV guy who was out the day before he said that these rods always stick and just to try harder trying to push it back in...This was impossible w/o use of a sledge hammer...The trailer was sitting unused since the beginning of Summer.
I really don't want to have to go through this every week... and currently it(blk water valve) is sitting open...all cleaned out...but stuck open...I'm afraid to use water now fearing that i will fill up the gray water holding tanks...
Is this a symptom of needing to replace something? I'd appreciate any advice (or empathy) The RV guy will be coming back in a few days to replace the original toilet...I have a feeling that he will be sending his kids to Ivy league colleges with the business I will be giving him this year.
..At least my hot water heater is cooking now...although I'm still taking showers at the gym.
Trailerbunny is offline   Reply With Quote
Old 12-15-2004, 03:57 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The valves do tend to stick, take a SMALL hammer, and tap gently until it starts to move back in. Then pull it out again, and work it back and forth until it moves fairly easily. After you get it shut, there are additives to the black tank water that will help keep this from happening in the future.
Old 12-15-2004, 04:09 PM   #3
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Depending on the location of the dump valve in relation to the hose connection, you may be able to spray some silicone spray inside to lubricate the blade path. Sometimes the rod itself binds on the brackets that hold the rod (if your Argosy has brackets that hold the rod) and sometimes that can be made better with a little silicone spray as well. If you can spray the blade in the valve, work it back and forth until it works freely.
Good luck!
Roger
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 12-15-2004, 04:31 PM   #4
Thanks for the input...All that I could find in my bag of tools is the "small' hammer and gun cleaning oil (don't know what's in that)...so I will have to head over to Wally World for the sillycone spray and a sack of coconuts (or was that coconut oil?)
Old 12-15-2004, 04:37 PM   #5
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Careful
You can find holding tank chemicals that do have coconut oil to lubricate the valve. I used some years ago and it worked just great. Of course, it wont help until you get the valve closed. I agree that a little tapping may do the job, but don't overdo it since those are plastic parts in there. I broke a valve years ago when it stuck and I got overeager. Fortunately, that one was exposed and easy to fix.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 12-15-2004, 05:18 PM   #6
Mine were very stiff when I got it. In fact, one rod was slightly bent from someone using too much muscle. Cleaning out the seals and using plenty of penetrating oil on the metal parts got them running smoothly again. However, only the "Holding Tank Seal Lubricant" got them pliable enough to actually seal as they should.
That stuff is coconut oil, you say? I figured it had to be some kind of vegitable oil. Colaws RV always has a bin of those various tank additives for $1 a bottle out front.
Mark
Pantry - Door coming open gwsullivan Cabinets, Counter Tops & Furnishings 8 09-23-2017 06:21 PM
New Unit Homepage Pahaska Our Community 4 10-07-2002 12:58 PM
Stuck Numbers? Mr Jody Hudson Forum Admin, News and Member Account Info 0 07-31-2002 10:13 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 12:19 PM
