Old 06-16-2012, 03:05 PM   #1
RedDogBullet's Avatar
2012 20' Flying Cloud
Anchorage , Alaska
Protechtor Series 2001 LP Detector Question
Our LP detector is indicating a steady red light with an occasional flash of yellow or orange. There is no alarm chirping. I have pushed the "test" button and it chirped a couple of times but didn't reset back to green. I can't find our exact situation in the owner's manual. Any ideas?
RedDogBullet is offline   Reply With Quote
Old 06-16-2012, 04:04 PM   #2
2005 19' Safari
GLENDALE , AZ
I think that is a self (internal) test error. Try removing ALL power (110VAC and 12VDC, i.e., disconnect shore power AND batteries) for 10-15 seconds, then power up again. That will reset the propane detector. If that is the problem, the LP detector should start flashing green again.
Old 04-02-2013, 04:10 PM   #3
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
I just had an "issue" with mine.
Noticed it had stopped flashing green every 8sec (normal) to
red/yellow every like three minutes: No "chirps".
TURNED OUT I HAD LEFT THE "STORE-USE" BATTERY SWITCH IN STORE.
I thought the Protector was supposed to be direct to the battery?
Del Gurney is offline   Reply With Quote
