Old 11-22-2006, 03:57 PM   #1
1976 31' Sovereign
Sioux Falls , South Dakota
Propane Weights and Measures
1. Liquid Propane weighs approx 4.26 lbs per gallon at 60 degs
2. A full 30lb Propane tank would weigh approx 75 lbs ?
3. A Propane tank should be filled to only 80% of capacity
to allow for expansion according to Federal Regulations
4. An empty 30lb propane should be filled with no more then
5.6 gallons to allow room for expansion or 80% full
according to the formula above.
5. An empty 30lb propane tank would weigh approx 51lbs. ?
6. I have had Propane dealers fill my 30lb tanks with as much as
7gallons of propane using a propane filling meter, they would
open up the bleeder valve and fill it untill liquid came out of
the valve, so 7gallons of liquid propane X 4.26 lbs per gallon
liquid equals 29.82lbs in a 30lb tank leaving no room for
expansion of the gas in warmer weather
7. My question is, was I in any danger with those tanks being filled
with 7 gallons or am I now just being paranoid
Gypsy George is offline   Reply With Quote
Old 11-22-2006, 04:14 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Welcome to the forum.
I did not follow all that but, if your propane dealer stopped filling when fog came out of the bleeder screw then you are okay.
Tom
Old 11-22-2006, 04:48 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ok, lemme see if I can sort this out a little bit:
Yep.
It'll weigh approx. 30 lbs + the weight of the bottle itself, which is marked as "TW" on the collar of the bottle. (If you want to know the exact weight of the propane, take the "WC" marking from the collar -- that means "water capacity" -- and multiply it by .42.)
Correctomundo.
Nope. The full weight -- TW + (WC X .42) -- is calculated with the 80%
amount already factored in.
Depends on the bottle. Check the "TW" figure on the collar.
It is not unusual to put 7 gallons into a 30 lb tank. Well, sort of unusual, given that many folks bring in their bottles for filling before they're completely empty.
Nope, no danger.
Lynn
WBCCI 21043
Old 11-22-2006, 08:21 PM   #4
Druupy's Avatar
2005 28' Safari
Port Orchard , Washington
Just did the porpane refill today.
I figure on 7 gallons in the 30# tank.
The way I find out what the fluid level is?
Weigh the tank.
Empty 30# tank = 20#
Full 30# tank = 50#
AND, all the new tanks have overflow protection valves. Meaning you can't over fill the tank because an internal valve closes and won't take anymore propane. The most I've gotten into an "empty" tank is 6.7 gallons, and that is what the filling station charged me for. At least it felt empty to me.
Druupy is offline   Reply With Quote
Old 11-23-2006, 09:33 AM   #5
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Exclamation
I don't have 100% confidence in the overflow protection devices, 98% maybe, but not 100%.
I like to see proper safety procedures when my tanks are filled.
snake is offline   Reply With Quote
Old 11-23-2006, 09:51 AM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Weigh the tank.
Full 30# tank = 50#
My 30G tanks have to be replaced, the local guy wants about $62 for the 30G and $68 for the 40G.
So I plan on getting the40's.
I already moved my battery inside back 3 feet, and removed the univolt, so the tongue weight will still be a bit lower.
If a 30 = 50lbs does a 40 weight 1/3 more or about 65lbs?
'77 Sovereign Intl 31' CB
Old 11-23-2006, 10:09 AM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
This chart was copies from the vintage trailer supply website
These numbers are for aluminum tanks. I would think the capacity would be the same for steel tanks.
Richard
Old 11-23-2006, 10:17 AM   #8
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Thanks, so it's about 10lbs more in propane and few more lbs in steel.
So 15 may 20 at most additional lbs.
Old 11-23-2006, 10:29 AM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Why not ask Santa for a pair of aluminum tanks? They are pricey and you need to polish them, but they do look nice!
Richard
Old 11-23-2006, 11:04 AM   #10
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Santa just brought me a GMC, his bag is empty
Old 11-23-2006, 11:10 AM   #11
2002 25' Safari
Dewey , Arizona
Images: 62
Wow, I like your Santa!
Richard
Old 11-23-2006, 11:25 AM   #12
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
oops, I saw a few nice dog toys in there, I'll e-mail him and ask if going to be in Arizona soon
Old 11-23-2006, 12:17 PM   #13
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Originally Posted by snake
I don't have 100% confidence in the overflow protection devices, 98% maybe, but not 100%. I like to see proper safety procedures when my tanks are filled.
Yes, that's why we're not supposed to rely on the OPD when filling a bottle here in NM. (I've been told that some fillers here do so anyway; I guess they're just too lazy or stupid to do a little mental calculating before using the scale that they all have by law anyway.)
Lynn
WBCCI 21043
Old 11-23-2006, 06:38 PM   #14
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
I wasn't trained on the filling procedure, but..... the guy at the rental place where I get my bottles filled waits for the OPD to stop the propane flow. That's how he knows the bottle is full, the shuts off the pump at the filling station. I'm not quite sure I completely understand the concept of the bleed valve when using a bottle with an OPD valve. It's not registering. I don't recall a bleed valve on the new OPD's, but haven't closely examined. If this is the method being used, the OPD would shut off when full. You're not paying for a full tank when liquid starts to vent but propane is still being supplied.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
My First Airstream - which TV? IceKing02 Tow Vehicles 11 07-06-2004 11:37 PM
Towing 76 sovereign with '95 E 150 rapidsraven Tow Vehicles 2 04-18-2004 10:04 AM
1963 Land Yacht J Goertzen Airstream Motorhome Forums 7 07-12-2003 07:37 PM
My first RV: 1971 Overlander? Roundhead Our Community 3 02-09-2003 08:31 AM
