Old 11-24-2006, 07:45 AM   #15
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Welll, it boils down to the propane recommendations in the National Fire Safety Assn propane manual, which individual states are free to adopt or to modify. For example, NFSA says to fill DOT bottles as on RVs either by weight (a scale) or by volume (using the bleed valve), but NM wants fillers to use weight unless volume is necessary. (It's an environmental thing: Filling by volume always shoots a certain amount of propane into the air.) Noteworthy is that the NFSA does not mention or suggest using the OPD valve as a means of filling.
But, again, the NFSA manual is a set of recommendations. It's possible that some state someplace could permit filling with the OPD valve. (And it's also true that a number of fillers in states that disallow using the OPD do so anyway.) Personally, I wouldn't: It's like trusting a mechanical device that sometimes fails with somebody else's well-being. Ultimately, if a filler illegally uses the OPD to fill, overfills a bottle, and an accident results, the filler could (and should) be held responsible.
Lynn
WBCCI 21043
Old 11-24-2006, 07:08 PM   #16
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
My 40# tanks usually take 9 gallons when empty. I'm glad to see that they weigh almost 100 lbs, I don't like carrying them, blamed it mostly on my age.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 11-25-2006, 01:21 PM   #17
1976 31' Sovereign
Sioux Falls , South Dakota
Propane weights and measures
Thanks everybody for your input, now feel safer knowing things
are ok. The weights I listed on the full and empty tanks were
done without actually weighing the tanks. Gypsy George
Gypsy George is offline   Reply With Quote
Old 11-25-2006, 04:33 PM   #18
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
You guys are good ! No where else on the internet could a person get better information with such good detail and discussion. That is why I read here quite a lot.
wingfoot321 is offline   Reply With Quote
Old 11-25-2006, 04:44 PM   #19
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by wingfoot321
... No where else on the internet could a person get better information with such good detail and discussion...
Well Duh!
Airstreamforums.com is comprised of the best of the best!
Tom
Old 03-17-2007, 08:34 PM   #20
walter1's Avatar
1964 22' Safari
Foresthill , California
LPG tank size
Duh, what size are my tanks???
My Manchester steel tanks are marked W.C. 71.4#
multiplying that by .42= 29.988
TW=25.6 (tare weight)
My old original steel tanks are marked PST WC 66.7
multiplying that by .42=28.014
Does that mean these are considered 30 pound tanks?
walter1 is offline   Reply With Quote
Old 03-18-2007, 04:10 AM   #21
TomW's Avatar
1967 26' Overlander
Call it manufacturing tolerance
Originally Posted by walter1
... Does that mean these are considered 30 pound tanks?
Yes.
Tom
My First Airstream - which TV? IceKing02 Tow Vehicles 11 07-06-2004 11:37 PM
Towing 76 sovereign with '95 E 150 rapidsraven Tow Vehicles 2 04-18-2004 10:04 AM
1963 Land Yacht J Goertzen Airstream Motorhome Forums 7 07-12-2003 07:37 PM
My first RV: 1971 Overlander? Roundhead Our Community 3 02-09-2003 08:31 AM
