Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-14-2002, 04:44 AM   #1
Profile:
Propane valve leak
Just got our 71 Safari a week ago and now am gradually checking out all the systems. Have not tried to light any gas appliances yet. However, yesterday when I opened one of the tanks, a white liquid spewed out of the top gasket of the requlator. I closed the tank valve and stopped right there. Didn't try anything else. Is the gasket bac? Should the regulator be replaced when I change to OPD or can a propane dealer fix it.
Dan
Dbraw is offline   Reply With Quote
Old 06-14-2002, 05:15 AM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Dan,
Normally propane white outgassing is liquid propane and is VERY DANGEROUS. You said it is coming out of the top?? does your regulator have a knob on the top to choose tanks?? or a window to tell you if it has switched for you? It could be someting as simple as an overfilled tank that has not been vented at the 80% fill. Or a bad regulator. There should not be any liquid in your propane system, let alone a white liquid. My reccomendation is to let a pro check it out. it may cost you a few $$ but you will know that it is safe.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-14-2002, 10:38 AM   #3
83Excella's Avatar
Profile:  1983 27' Excella
Airstreamville , Kansas
Leaky LP tank
Dan,
Call some gas refill places and see what they say, but call a few to be sure your being given the right information.
My $0.02 cents worth less tax is you may have water in your tank and its foaming and or bubbling when it spews out giving it a white look, I think water is heavier than the LP but cant remember for sure.
John
83Excella is online now   Reply With Quote
Old 06-14-2002, 06:12 PM   #4
Profile:
BretG & John,
Thanks for the advice. I will do as you said and have a pro check it out. I am afraid of gas and don't want to go sailing up in the sky from a gas explosion. It sure is nice being able to have some questions answered about the Airstream. Makes the decision to buy one much easier. We are not in a hurry to get on the road anyway. Have to check out breaks, and a few other things first. Plus rebuild some cabinets and furniture. Hope to get on the road by fall.
Thanks again,
Dan
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Dump Valve Leak David Hall Waste Systems, Tanks & Totes 8 02-17-2004 05:26 PM
Propane Leak roessler LP Gas, Piping, Tanks & Regulators 6 01-22-2003 11:21 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
