Old 05-15-2007, 10:46 AM   #15
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I have to confess that I was not very prudent with propane when we went to AK last year. Seems like we used the furnace most evenings to ward off the damp chill. We ran the furnace quite a bit and I left the fridge run on propane rather than switch to elec when we could. Nice that propane is dirt cheap up there.
Might have been two weeks - but I don't think it was much more.
Since then I bought a Vornado heater for cool weather camping. Best thing since crushed ice.
Pat
pmclemore is offline   Reply With Quote
Old 05-15-2007, 10:52 AM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Pat, is block ice cheaper than propane in Alaska?
Uses no propane but is heavy and will never last a week between refills! [no gratuitous smily use here, no sir!]
5 meter Langford Nahanni
Old 05-15-2007, 10:54 AM   #17
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Water heater use
To keep the water heater on throughout a trip uses too much propane to suit us. Unless we're planning to take a full-on shower, which is basically once a trip while boondocking, we don't fire up the water heater. For dishwashing, we heat a couple of cups of water on the stove, and mix with tap water. Same for sponge bathing. However, to avoid the buildup of spider webs in the gas feed tube to the water heater, we treat ourselves to the once-a-trip hot shower, assuming we have enough water left.
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 05-15-2007, 01:04 PM   #18
2005 30' Classic
Images: 12
Sorry to be detailed here, but I'm a little confused: are we talking boondocking or are we talking using the propane to keep things in the frig cold and the water hot until we get to a serviced campground? Some, maybe both?
GetOutDoors is offline   Reply With Quote
Old 05-15-2007, 01:10 PM   #19
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
We are talking about not going to service campgrounds at all~ all stand alone camping.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-15-2007, 01:19 PM   #20
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Thumbs up
My kind of campin'!
Old 05-15-2007, 01:32 PM   #21
2005 30' Classic
Images: 12
That was my understanding by the thread title.
Old 05-15-2007, 01:51 PM   #22
2005 30' Classic
Images: 12
I have a built-in Onan RV QG 2500 LP generator that uses .2 - .6 gallons of propane per hour, depending on load. It is used to run the micro and refresh the batteries, maybe 1 - 2 hour per day. At that rate, it alone could consume 5 gallons of propane per week.
The local dealer tells me he doesn't like to install generators for this reason, but I like it. It's just too easy to carry backup tanks for the comfort.
Old 05-15-2007, 02:49 PM   #23
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Although I think some of us have talked about our overall usage over the course of a season, which may include sites with power.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-15-2007, 04:59 PM   #24
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
That is my favorite kind of camping too! Not counting running the furnace which we don't run in the summer -- we go thru one 30# tank every two months in the summer.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 05-18-2007, 11:04 PM   #25
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I just dewinterized, fired the water heater up and cycled it, etc...
A couple of days later, I was outside by the trailer, and hear the water heater fire up, and think...dangit, I forgot to turn it off.
So I begin to check propane.....the valve was on the curbside tank so I take it off and it is near empty, so I check the other one and it is near empty as well, but should have been full.
So I start leak testing....the rubber lines to the valve had gotten hard and unpliable....and were leaking bigtime.
My guess is that over the course of the winter, I lost almost the entire streetside tank, and my oversight on the water heater cost me the curbside tank.
I now have new hoses, and have checked my propane system for leaks.
So I take off the
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 11-11-2007, 01:18 PM   #26
Fenghuang's Avatar
2007 23' Safari SE
San Diego , California
Efficient inside/outside cooking techniques/modalities while dry-camping/boondocking using propane with no generator or open fires allowed.
As a foodie hobbyist, I enjoy cooking, experimenting with recipes, and eating outdoors weather permitting. With the recent horrific fires in San Diego County, the red flag warning status continues to be observed at County campgrounds prohibiting open fires (charcoal or campfires).
What cooking technique/modality is most efficient to prepare a cooked meal from raw ingredients using the minimal amount of propane? Please share recipes and/or references/links.
Larry
1767 Spanish scribe:"Rash judgments are always accompanied by ignorance and absence of light." (Learn all the facts before making a judgment)
Fenghuang is offline   Reply With Quote
Old 11-11-2007, 02:17 PM   #27
lewster's Avatar
Naples, FL , Hood River, OR
Larry
Hi Larry,
I use a Solaire infra-red grill and a wok-like insert that is actually perforated with a flat bottom and 4 sloping flat sides (Lowes or HD). I se this to stri fry ust about any type if veggie. Works well if you get the 'wok' really hot. Just a coupel of quick minutes and you're done!
Old 11-11-2007, 04:33 PM   #28
_
[What cooking technique/modality is most efficient to prepare a cooked meal from raw ingredients using the minimal amount of propane? Please share recipes and/or references/links...
the common pressure cooker is the most efficient method for cooking the widest range of foods...
and with virtually any fuel source.
of course microwave ovens may actually use LESS energy but that's another topic.
i like the ceramic cookers and grill inserts too...stir fry by any method is fast and tasty...
there are other threads on this topic
http://www.airforums.com/forums/f48/...chen-5410.html
http://www.airforums.com/forums/f48/...ing-21910.html
and loads of websites on pressure cookers...
along with recipes.
cheers
2air'
Energy Efficient Cooking
Efficient Cooking
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
