Old 10-21-2003, 07:30 PM   #1
Swingking's Avatar
Question Propane tanks question
Hello fellow airstreamers!
I just spent $160 on...
new propane tank valves
new regulator
two 40# tank fills.
I put it all together (with the expensive gas thread tape) and turn on the valves and .... nothing.
stove burner wont light.
I don't hear a hissing sound and I can't smell any rotten eggs.
any reason why the propane isn't flowing?
thanks!
Mark
mholcomb@ausitn.rr.com
Swingking is offline   Reply With Quote
Old 10-21-2003, 08:29 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Each appliance has a cut off valve near it. I would check those first to see if they are closed. They will be a small in line petcock.
If that does not work, I would remove the tanks and make sure that cracking the valve allows gas to escape. If it does and the valves are open I would then look at replacing the regulator.
Do you have both tanks open?
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-21-2003, 08:41 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
One last thought, I've been told to turn the gas bottles on slowly. A sudden rush of gas has been known to cause the safety in the new tank to shut down the gas flow. Try turning off the tanks and then turning them back on again.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-21-2003, 08:57 PM   #4
Swingking's Avatar
I thought is was the small valve you spoke of... but that was open as well.
I have both tanks wide open.
should I try removing the rubber flexable hoses then reinstall?
thanks for your help!!
Mark
Old 10-22-2003, 05:26 AM   #5
ke4pk's Avatar
Images: 8
Sounds like a bad regulator to me. Disconnect at the point where the hoses connect to the regulator and see if the gas will flow.
ke4pk is offline   Reply With Quote
Old 10-22-2003, 01:09 PM   #6
Swingking's Avatar
well...
the "open the valve slowly to pressurize the lines" idea worked!
I found a leak in the line from the regulator to the gas line going under the trailer.
I disconnected this line and found some crud in the seating. cleaned it out... no more leak!!
thank you soo much for the advice!
Mark
http://24.153.183.242/airstream
Old 10-22-2003, 09:24 PM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Originally posted by Swingking
well...
Mark
Mark, it was a long shot but I have heard of this before and your experience pretty much confirmed its an issue to remember.
Glad it worked!
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-22-2003, 09:27 PM   #8
Chas's Avatar
Images: 22
So JC,
I guess this is essentially the safety device they put in what, the OPD tank valves, in case of a hose rupture?
If so it makes good sense to me. Inquiring minds want to know??
Chas
Chas is offline   Reply With Quote
Old 10-22-2003, 09:55 PM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
Originally posted by Chas
So JC,
Chas
Chas,
Yep this is one of the lesser known features of the OPD valves. Most everyone knows about the overfill protection and the easy connect threads. I was informed of this from Leroy at Bill Thomas Camper Sales when I took delivery of my Safari in 2001. He said turn the gas on slowly.
Jack
Jack Canavera
STL Mo.
AIR #56
Propane tanks storage question GoNomad Winterizing, Storage, Carports & Covers 2 08-27-2006 09:50 PM
New Propane Tanks... Sneakinup LP Gas, Piping, Tanks & Regulators 10 01-31-2004 05:15 PM
Propane Tanks: 30# or 40#? Navigator LP Gas, Piping, Tanks & Regulators 11 12-14-2003 03:08 PM
new or old propane tanks striker LP Gas, Piping, Tanks & Regulators 30 02-22-2003 02:32 PM
propane tanks david h Our Community 5 01-12-2003 07:49 PM
