10-18-2008, 05:24 AM
#21
2007 27' Safari FB SE
LONDON
, ON
Originally Posted by eubank
Pretty interesting site. One small problem: Cylinders are rated by their weight capacity for water, not propane. If you look at the collar of your cylinder, you'll see a number after the acronym WC, which stands for water capacity; there's no indication for capacity in pounds of propane. (If you multiply WC by .42, you'll get the weight capacity for propane.)
According to Worthington, the maker of the vast majority of propane tanks, what I said is true: a 30lb propane tank will hold 30 pounds of propane which is also 7.1 gallons.
Here is the chart with specs for other sizes of tanks:
Steel 4.25 lb. - 60 lb. Specifications
We pay $18 to fill a 30 lb tank at the local Costco by the flat rate charge and last summer I paid $35 in Cape Cod by the gallon ($4.50, IIRC).
10-18-2008, 07:09 AM
#22
Moderator Emeritus
1972 31' Sovereign
High Springs
purman, those gauges that screw on to the tank just read the vapor or gas pressure. The pressure is constant until the liquid runs out. They give no real indication of how much liquid is in the tank, so they are about worthless.
Another thing to consider, those pre-filled tanks at gas stations, HD and Lowes are 20# cylinders, but they only fill them to 17#. Kind of a rip off, for what they charge for them these days. Good help is hard to find in a country of 300 million employed folks, so they short the cylinders so some minimum wage employee does not put 21 # in a bottle and blow your local HD store to smithereens.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
10-18-2008, 07:22 AM
#23
2002 25' Safari
Dewey
One reason that the cylinders come up short is OPD. The float valve inside the cylinder is designed to stop the filling of the bottle at around 80% of capacity.
Richard
10-18-2008, 07:26 AM
#24
1999 23' Safari
Perrysburg
, Ann Arbor
How to KNOW ...
I got tired of finding places that only would sell me a tankfull, rather than a topoff. If I've only used fifteen pounds, I don't want to pay for thirty! And I don't trust the little green/red widget / "reserve" switch gizmo on the regulator. (Andy Grove, CEO of Intel has that little book out, "Only The Paranoid Survive!")
So I went "simple" - I only open the valve to one tank. When it's really and truly empty, the gas just stops, stove goes out, etc. Then I run out and close that tank's valve and open the other. Takes all of thirty seconds, and I KNOW I'm operating from a full tank. Next time I fill up the now-empty one, I don't care if they demand I buy a tankfull, 'cause I actually want a tankfull!
Only time this would cause me an issue would be if I were using the furnace (rarely) and it went out in the middle of the night and I had to dash out into the cold and change valves. Hasn't happened yet. Knock on wood.
10-18-2008, 08:12 AM
#25
1968 28' Ambassador
Cedaredge
So are then any gages that work????
Other than installing a scale under my tanks
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
10-18-2008, 08:30 AM
#26
Airstream - Other
Bosque Farms
, New Mexico
Oh, if you lift about a zagillion cylinders, you get to the point that you can guesstimate the amount of propane in them pretty well. Lifting bottles that often means a whole lot of Airstreaming, and I'm ready for it!
Lynn
ACI Big Red Number 21043
10-18-2008, 12:56 PM
#27
LONDON
, ON
I'm going to give one of these scales a try. They are about $20-$25.
Balanzza
10-18-2008, 01:48 PM
#28
1968 28' Ambassador
Cedaredge
That thing looks cool.... Might give it a try... but then I have to take the holders of the tanks to do it...
Well it's not like I have anything better to do while hanging out at camp... Another gadget to play with... YEAH>>>
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
