Old 11-17-2008, 01:23 PM   #1
1972 25' Tradewind
plano , Texas
propane tanks
does anyone know if it is better to replace the valves on the old tanks or just buy new tanks and if so what brand and type should you buy
roguebrun is offline   Reply With Quote
Old 11-17-2008, 01:31 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
If your old cylinders are in good condition (no heavy-duty rust, no dents, no bent collars), then it's worth your while and your money to have the old ones retrofitted with new valves and recertified.
Lynn
WBCCI 21043
Old 11-17-2008, 01:46 PM   #3
1972 25' Tradewind
plano , Texas
where is a good place to get the valves changed and recertified
Old 11-17-2008, 01:48 PM   #4
cameront120's Avatar
1972 25' Tradewind
Check with a bulk propane supplier. They either do it, or can point you in the right direction. Look up Propane in your yellow pages. Best of luck!
North Vancouver, BC
Old 11-17-2008, 01:52 PM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Propane valves and re-certification
This is an excellent article on the subject..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 11-17-2008, 05:37 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If they are aluminum tanks you definitely want to keep them.
Richard
Old 11-17-2008, 05:40 PM   #7
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
If steel
Yes, aluminum - keep - if steel, then throw away and get new ones... just my two cents
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 11-17-2008, 05:46 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
If steel, you could toss them and get aluminum tanks. They look great when polished.
Richard
Old 11-17-2008, 05:51 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Let's see, $25 for a new valve vs $150 + shipping for a new Worthington aluminum tank. By the way a new aluminum tank may not be exactly the same height as your old ones. In NM nobody ever asked about recertifying tanks and nobody in any other state asked if they were. They just look at the different shape valve. If you want to get rid of those old nasty aluminum tanks and put on nice new white painted steel tanks let me know I'm your man.
Old 11-17-2008, 06:35 PM   #10
Mexray's Avatar
1978 28' Ambassador
Morada , California
Lumatic...have you no shame.... I agree, send those 'old nasty aluminum tanks' out our way...
Really, though... your aluminum AS needs aluminum tanks...just change the valves, I did it on our 78 AS...cost only about $30 which included a new pressure test - aluminum tanks last just about forever if there's no corrosion on em'...
Ray in Northern Calif.
Ray & Pat; Morada, CA
Old 11-17-2008, 06:43 PM   #11
1963 24' Tradewind
San Diego , California
I have 2 large aluminum tanks that had the old valves date on the tanks 1973, the tanks were in good condition. Had the valves switched over, i think they were $35. ea. the old tanks were also certified (san diego thing ?). I'm happy
Sixty3TW4US is offline   Reply With Quote
Old 11-17-2008, 07:58 PM   #12
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Agreed, especially if they have the highly undesirable external gauges!
I’ve even got a couple of nice new steel 40lb OPD bottles for consideration.
Vaughan
Old 11-18-2008, 09:17 AM   #13
Dan@LED4RV's Avatar
Denton , North Carolina
old vs new
Originally Posted by roguebrun View Post
is it better to replace the valves on the old tanks or just buy new tanks
If you have steel tanks you are going to want to replace them. Just buy them local. It they are aluminum tanks you definitely want to keep them like AZFLYCaster says.
Aluminum tanks have differant valves from steel tanks. It has to do with the shape of the tank. Any place that can pressure test the tanks can take the old valves out and put the new ones in. They most likely won't have the Valves for the aluminum tanks.
Click here to see the 30lb valve
Click here to see the 40lb valve
Also, click here to see the whole rundown on OPD Valves.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
See through propane tanks Janet H LP Gas, Piping, Tanks & Regulators 55 09-07-2014 12:46 AM
need new propane tanks for 96 Ltd. raystream LP Gas, Piping, Tanks & Regulators 3 02-26-2008 04:56 AM
Propane Tanks: 30# or 40#? Navigator LP Gas, Piping, Tanks & Regulators 11 12-14-2003 03:08 PM
new or old propane tanks striker LP Gas, Piping, Tanks & Regulators 30 02-22-2003 02:32 PM
propane tanks david h Our Community 5 01-12-2003 07:49 PM
