Old 09-12-2019, 10:20 AM   #1
TinyTin
TinyTin's Avatar
2006 25' Safari
San Antonio , Texas
Propane Tanks
Having to replace my two tanks due to age. Looking at Worthington or Flame King. Any advice or reviews would help before I buy
TinyTin is offline   Reply With Quote
Old 09-12-2019, 11:09 AM   #2
2018 19' Flying Cloud
New York , New York
The only practical advice in this matter is: be as careful as possible. In fact, there is nothing complicated in replacing, but I knew people who had problems with this.
It’s not worth saving on cylinders, your safety depends on it
Tom_Cooper is offline   Reply With Quote
Old 09-12-2019, 11:47 AM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Do you have steel or aluminum tanks? I have the original aluminum tanks on my 1979 Safari and have just replaced the valves to recertify. You can probably do the same thing with steel tanks, but it may be more economical to just replace steel tanks with new.
Bill
Just my personal opinion
Old 09-12-2019, 04:25 PM   #4
Kevin245's Avatar
If they are steel tanks Id simply replace them. Aluminum tanks are worth having them inspected and recertifications.
Eleanor Roosevelt
Old 09-12-2019, 06:55 PM   #5
2018 25' Flying Cloud
Portland , Oregon
When I replace mine I'll get tanks with float gauges. Uhaul sells them, I know. It doesn't let me post the full URL for some reason so you'll have to navigate on your own. https://www.uhaul.com/MovingSupplies...ts-Accessories
daleyocum is offline   Reply With Quote
Old 09-12-2019, 07:43 PM   #6
TinyTin
TinyTin's Avatar
2006 25' Safari
San Antonio , Texas
They are steel. It is on a 2006 Safari.
Old 09-12-2019, 08:15 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
I bought new Worthington tanks from Home Depot.
CRH is offline   Reply With Quote
Old 09-14-2019, 06:04 AM   #8
Kevin245's Avatar
IIWM Id purchase new tanks. Our local propane dealer gave a a whale of a deal on our last steel and aluminum sets.
Eleanor Roosevelt
Old 09-14-2019, 08:06 AM   #9
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Worthington. Done.
wulfraat is online now   Reply With Quote
Old 09-14-2019, 09:22 AM   #10
dmcgaugh's Avatar
Seattle , Washington
I bought Manchester tanks with float gauges. It sure is nice having gauges.
dmcgaugh is offline   Reply With Quote
Old 09-14-2019, 10:17 AM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
As long as they are not rusted or obviously damaged, a re-certification is dirt cheap in most areas. The tanks should be good for a *very* long time unless they are abused.
Indeed if you are going to upgrade then aluminum with gauges is the way to go.
Old 09-14-2019, 10:55 AM   #12
richw46's Avatar
Lexington , Kentucky
There is probably a place near you that will recycle/scrap your old tanks. Please don't just put them in a landfill. There will be an extra charge to get the new tanks purged the first time you get them filled.
Southern States is a good place to get them filled, although not all SS stores carry propane. Tractor Supply is another good store for the best rates.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-14-2019, 11:49 AM   #13
Half a Rivet Short
Hi
Last time I had a 40 pound tank filled at the local Agway it was just under $18. Filling the same tank at an RV centric place is about twice that. Indeed the fill price at Agway was significantly less than the "swap out" cost on a tank half that size at any of the local stores.
That's not actually a plug for Agway, only a suggestion that you can save some money by shopping around. Also, just like the price of gasoline, the price of propane *does* fluctuate. I may well have caught the all time low price last time I filled up.
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
Replacing water tanks, holding tanks & battery? Nelsons 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
