Old 05-23-2019, 02:25 PM   #1
ASLover
2007 25' Safari FB SE
Louisville , Kentucky
Propane tank “Y”
Is there any issue with putting a “Y” on the primary tank to be able to run auxiliary devices like a generator or grill?
I have a 2007 Safari 25 FB SE and it does not have a low pressure outlet. Thinking the “Y” is the easiest solution.
Greg
gregshade is offline   Reply With Quote
Old 05-24-2019, 12:18 PM   #2
Johnco's Avatar
2006 19' Safari
Anaheim , California
I've used one without issue for years. It's placed between the tank and the "pigtail" so anything you run off the feed will need a regulator but both my campfire in a can and my O-Grill are set up with regulators.
Think like a Proton-Stay Positive!
Johnco is offline   Reply With Quote
Old 06-19-2019, 10:50 PM   #3
2011 20' Flying Cloud
SACRAMENTO , California
I see a few different models and types out there (all with complaints that they leak, if not initially, pretty soon after install). Which one do you use?
johndorst is offline   Reply With Quote
Old 06-20-2019, 04:47 AM   #4
dznf0g's Avatar
Oswego , Illinois
I've used an extend a stay for about 5 years. No leaks yet....
-Rich-
Old 06-21-2019, 09:33 PM   #5
ASLover
I used the Gauge Master and it works well.
Old 06-22-2019, 05:38 AM   #6
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Our low pressure outlet is low near the belly in between the frame and battery box. Easy to miss. I thought all airstreams had one? When did they start adding them?
BigSxyWhtGuy is offline   Reply With Quote
Refrigerator, propane heater, air conditioner, water pump, propane water heater Tanglewood Airstream Classifieds 0 05-09-2018 06:08 AM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
