Old 12-11-2013, 12:45 PM   #15
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
I have been told that on the newer tanks the way to tell the size of the tanks is the number of rings...
1 ring = 20 lbs
2 rings = 30 lbs
3 rings = 40 lbs
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 12-11-2013, 01:28 PM   #16
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
In addition to the manufactured date stamped on the collar, there should be the empty (tare) weight of the tank as well as the full weight. The difference would be the capacity, e.g. 30#... If the supplier fills the tank by weight, they should be setting the scale to the full weight shown on the tank in order to shut off the pump when it reaches that weight. Some rarely see aluminum tanks and occasionally set the scale from memory for what the heavier steel tanks weigh, then the OPD kicks in so at least they can't in theory overfill the tank.
And yes, a full 30# aluminum tank weighs only a few pounds more than a full 20# steel tank. While they still have to be certified, they don't rust and should last a lifetime short of physical damage or theft.
I believe part of the dealer prep on new trailers is to install a large level centered below the front window. It's real handy when pulling up on ramps to know when the trailer is level side to side as it is visible through the rearview mirror over the 30# tanks. I've seen more than one trailer with the 40# tanks and since they come up to bottom of the window with the cover in place, the level is hidden behind them. If the trailer came from the factory with the 40s installed, it would have been better if they mounted the level on the front of the cover well above the jack.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 12-14-2013, 08:44 AM   #17
1972 Travelux Princess 25
Cobourg , Ontario
Originally Posted by Uppie89 View Post
Thanks for the input guys. I would trade the pair a just bought for one of the taller ones so I have a pair of the bigger ones. If anybody knows of one somewhere.
Contact your local propane dealers. They often supply fresh tanks on an exchange basis, they should be happy to take yours in trade. This is probably the easiest solution, just swap your tanks for full ones.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 01-02-2014, 08:34 PM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Thirty pound tanks hold ~ 7 gallons of propane. Whether they are aluminum or steel.
Your propane supplier should know the difference in the filled weights of the two types of tanks.
The weight is stamped on the handle ring.
