Old 09-01-2006, 06:16 AM   #1
1977 31' Sovereign
Erie , Pennsylvania
Propane Tank Noise
Good morning all, I have a strange (or stupid) question about my propane tanks. I just updated them to OPD with new hoses and a new regulator. When I run the refrigerator and the water heater at the same time I hear this noise coming from the tank that sounds like there's a large bee stuck in side buzzing around, when the water heater shuts off, the sound stops. It didn't make the noise before I upgraded, so is this just the norm for these valves when drawing alot of propane, or is there something wrong with the valve, or am I just being paranoid.
jrk247 is offline   Reply With Quote
Old 09-01-2006, 08:26 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I have a tank or two that buzzes. The 20 pounder I am using on my gas grill does it. Grill works fine, I am not worried about it.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-01-2006, 08:45 AM   #3
2006 30' Classic
Farmington , New Mexico
Images: 14
jrk247--- I had the same thing happen this summer --It just about drove me crazy chasing that thing. Ours was a "buz-hum-moan-vibration" that would come and go depending on the amount of propane flowing. To make a long story short I cured my with new hoses. This was a trial and error thing that took me through the replacement of one tank valve, the regulator and both hoses. I couldn't pin it down by sound or feel. After each item was replaced I thought it was fixed only to have it start again. Finally the hoses fixed it. Looking back on it I'm not sure the hoses were bad either but that they were bent at such an angle to cause a partial crimp in them makeing the noise. Our noise started after we were in some extremeely hot weather. I think now the heat may have softened the hoses while kinked and caused this. That said try rotating your tanks so the hoses have as little bend in them as possable and see if this doesn't cure it. -------------Pieman
Mike Lewis is offline   Reply With Quote
Old 09-01-2006, 08:52 AM   #4
1977 31' Sovereign
Erie , Pennsylvania
My sound's looking like it is more of an annoyance than a real problem, which is good. . The hoses and everything are new, that means alot since it didn't do it before with the old hoses! I'll try moving them around, I just wanted to make sure my tank wasn't going to explode while I'm trying to eat dinner!
Old 09-01-2006, 10:52 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
We have one that does the same thing, I took it off our coach, and am using it on our grill now. It gave no problems, other than the groaning noise under heavy gas use.
Old 09-01-2006, 01:52 PM   #6
2006 30' Classic
Images: 14
quote:My sound's looking like it is more of an annoyance than a real problem
jr---you're right it is anoying. It's not bad untill you open the front window. though slightly anoying the more i listened the more it bugged me.--pieman
Old 09-01-2006, 02:28 PM   #7
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Yea, mine makes a groaning noise, but only after it has been filled and I lift it on to the trailer.
Oh, that was me.
Michael
ArtStream is offline   Reply With Quote
Old 09-01-2006, 05:16 PM   #8
Well Preserved
1993 21' Sovereign
Oh, that was me.
Michael
Sometimes it's tough to tell the difference between the groaning of an Airstream, and the groaning of its owner...
Old 04-19-2013, 09:12 AM   #9
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Fast forward, my propane bottles, regulators have started buzzing. Two days ago the 1 gallon BBQ bottle viberated when I lit the BBQ. Sound went away in a few minitues. Yesterday and this morning the 7 gallon tank makes a humming noise when the furnace comes on. The sound goes away in about 5 minutes. This is something new. All that is changing is our altitude. The tanks were filled at sea level. Two days ago we were at 5,000'. Now we're at 7,000'.
Any ideas on what's happening?
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 04-19-2013, 09:16 AM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
It may be temperature related. OPD valves have to allow gas to escape when the float valve is closed, and instead of using a backcheck they just have an orifice that allows a reasonable amount of gas to flow but that is small enough to prevent liquid from passing through quickly enough to pose a problem.
If the temperature is warmer than it was when the tanks were filled, it's possible that the float valve is fully closed and the gas has to go through the orifice until the tank is depleted enough to allow the float valve to open.
Hose-related problems may be due to kinking or to something being stuck in the excess flow check valve built into the acme connector.
Old 04-19-2013, 09:39 AM   #11
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Regarding temperature. It was 90 when we filled the bottles. It in the 40s here.
Antique Pedaler
Old 04-19-2013, 10:56 AM   #12
2009 34' Panamerica
weyburn , Saskatchewan
Every trailer I have owned has done this, if there is a high demand like furnace or hot water heater running. I believe it just the regulator spring moving. It tells me everything is working fine lots of flow and has never worried me.
Pedecanada is offline   Reply With Quote
Old 04-19-2013, 01:28 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a 20# propane bottle with a stuck OPD valve. It's been that way since the last time I had it filled. The guy didn't use a scale when he filled it. I thought these tanks could not be over filled. But comparing it to a tank I just had filled, this tank is 4 lbs heavier.
I have banged the tank vertically on a solid surface in hopes it would free the stuck valve.
Opened the valve veerrry slowly. Nothing seems to work. Even opened the vent screw and let it blow for 15 minutes.
Is there anything else I can do before exchanging one full tank for another?
Old 04-19-2013, 01:43 PM   #14
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Some info first: What is the TW marking on the collar of the cylinder?
Lynn
WBCCI 21043
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
Propane tank charlief1317 Airstream Motorhome Forums 14 01-04-2003 08:00 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
