Old 04-19-2013, 07:09 PM   #15
2010 25' FB Flying Cloud
mcminnville , Oregon
I think the new hoses solved the problem because of flow. I recently learned that different colored connectors denote the maximum flow of that connector. I had noise, put on the high flow connector, no more noise.
pal50 is offline   Reply With Quote
Old 04-20-2013, 07:16 AM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
eubank; the TW is 18.25
Old 04-20-2013, 07:58 AM   #17
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ok, Doug, then your full cylinder should weigh no more than about 38.25 pounds. If it's been overfilled, then bleed off enough to reduce the weight to that point. Do so outside in a well ventilated area with absolutely no source of spark nearby. Since you have to bleed through the tiny hole, it'll take a while, depending on how overfilled it is.
If it has a bad OPD valve, you can continue to use it safely until it's empty, but then you should have the valve replaced at a full-service propane dealer. If you have aluminum cylinders, then they'll likely have to special order the proper OPD valve.
You can also test the rig's regulator by simply hooking up the cylinder to a known-good barbeque grill that has its own regulator.
Lynn
WBCCI 21043
Old 04-20-2013, 09:15 AM   #18
Antique Pedaler's Avatar
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Humming stopped after a day. Pressures equalized?
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 04-30-2013, 01:20 AM   #19
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Discovered this on my 2nd shakedown trip of our preowned 2008 Classic FB this weekend in Missouri. Weekend weather was cool and rainy turning to sunny and warm today. It was cool enough not to use the AC but not cool enough to use the furnace. It was quiet and I could hear the buzzing while in bed in our front bedroom. Threw on my pants and slippers and went outside about midnight with a flash light and discovered the sound coming from the propane tank area. The only gas appliance on was the fridge. I was testing the fridge LP system. I turned the fridge off and no buzzing. Very annoying to me even though my hearing has suffered over the years the frequency bugged me in bed. The sound goes right through the windows and walls. I had to switch the fridge to electric.
I have a laundry list of major issues with this newly acquired AS that the dealers 90 warrant should cover but I'm not sure this is one of them. The tanks were topped up prior to deliver several weeks ago and I remember one of them was leaking a tiny bit out the pressure release but that has gone. I was testing the furnace also during the day as it was in the 50s and damp
Kelvin
Old 01-16-2017, 05:55 PM   #20
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
No its not hard to tell... if its the owner ... its a higher pitched squeeking sort of sound... where as if its the airstream... its a lower pitch and constant reminder...
GM Airstream is offline   Reply With Quote
Old 01-16-2017, 08:22 PM   #21
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Propane Tank Noise
The noise is the regulator. It's the round device the hoses go into. There's a cap on it. Inside you will find a large screw. This is the adjuster for pressure out put. If the stove doesn't light it would be low pressure causing it. Turn the screw in to raise the pressure (output). The groan is the diagram in the regulator. It is modulating.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
Propane tank charlief1317 Airstream Motorhome Forums 14 01-04-2003 08:00 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
