Old 07-01-2004, 10:46 PM   #15
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Originally Posted by DavidsonOverlander
I thought that one of them still had some propane in it because it's 8 pounds heavier than the other
Grant, look at the markings around the collar of the tanks. One of the markings should have the letters TW followed by some numbers. TW stands for Tare Weight, which refers to the weight of the tank without propane. If you have an empty tank, it should weight at or near the TW.
If both tanks are the standard 7-gallon size, their TWs should be fairly close, though not necessarily identical. Our two tanks were bought side-by-side, same store, same manufacturer. They have different TWs.
Lynn
WBCCI 21043
Old 07-02-2004, 08:03 AM   #16
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Lynn
Thanks Lynn, I guess the difference in weight is not due to propane. One tank has a TW of 24, the other is 30 1/2. They appear to be the same, but maybe were made by different manufacturers.
I've ordered 2 aluminum tanks from Airstream Dreams and I have a new regulator that I got from Inland RV, so hopefully I will soon be able to try out the stove, fridge, furnace and water heater.
Grant
DavidsonOverlander is offline   Reply With Quote
Propane Tank Cover tmeagle1 LP Gas, Piping, Tanks & Regulators 6 03-04-2004 07:30 PM
Propane Tank Emptying & Certifying drober05 LP Gas, Piping, Tanks & Regulators 1 11-03-2003 11:35 AM
Propane tank cover.... drboyd LP Gas, Piping, Tanks & Regulators 2 07-29-2003 03:42 PM
Propane tank gauge Jim Miller LP Gas, Piping, Tanks & Regulators 6 04-09-2003 04:25 PM
Propane tank charlief1317 Airstream Motorhome Forums 14 01-04-2003 08:00 PM
