Old 10-20-2014, 07:46 PM   #1
Wayward's Avatar
Cary , North Carolina
Propane tank mat - quik mod
I pulled a propane tank to get a refill and found tank bases are wearing through the paint on the steel tank base.
A nearby Tractor Supply store had propane for $2.50. They had some very heavy duty 4' wide rubber mat sold by the foot. It is 1/4" thick. I bought one foot for about 5 bucks with tax.
After cleaning the pan out I gave it a good spray of Corrosion-X, then traced the base and cut a pad for the tanks to sit on. Tough stuff to cut. Seems like it is made from ground up tires. I used sheetmetal scissors but a sharp utility knife would do.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-20-2014, 07:48 PM   #2
dznf0g's Avatar
Oswego , Illinois
Very nice! I just cut rubber fuel line lengthwise and slip it over the rounded foot ring of the bottles.
-Rich-
Old 10-20-2014, 07:53 PM   #3
Wayward's Avatar
That'll work too! Good idea
I may try that on the bottom edge of the propane tank cover.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-21-2014, 03:41 PM   #4
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Nice!!! Great idea!
Skatiero is offline   Reply With Quote
Old 10-21-2014, 04:17 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Keep in mind that if you have an older unit with electric level gauges, the system depends on ground from the tank base in order to operate properly! Adding the mat will insulate the tank from the frame rendering the tank insulated! You can avoid this by running a ground wire from frame to one of the sending unit screws!
Old 10-21-2014, 04:58 PM   #6
dznf0g's Avatar
Oswego , Illinois
They still get a ground through the hold down bracket. Good catch though...if you ever get an erratic signal, clean the threads and clamps for the bracket.
-Rich-
Old 11-03-2014, 10:53 AM   #7
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
Hi, thanks for the good idea. But... does it allow water to dry out that gets between the mat and the steel tray?
I'm looking for something similar. My A/S had a plastic grid between the propane bottles and the tray, but it's falling apart.
Don
DJW is offline   Reply With Quote
Old 11-03-2014, 11:25 AM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Don
This looks like a job for rubber link floor mat: Tire Link Floor Mats are Tire Tread Rubber Door Mats by American Floor Mats
A mat like this will allow liquids to drain through it.
Cats and ultraleather Airstream upholstery don't mix!
Old 11-03-2014, 11:27 AM   #9
dznf0g's Avatar
Oswego , Illinois
Or this:
http://www.amazon.com/Crown-Safewalk...MYFJQ7W8212D4Z
-Rich-
Old 11-03-2014, 11:32 AM   #10
That one would be easier to cut to the right shape, all right.
Old 11-03-2014, 12:39 PM   #11
DJW
DJW's Avatar
2004 25' Safari
Wow! Great ideas all. And, it reminded me of something I used on my houseboat, years ago-
DRI DEK Dri-Dek Panels | West Marine
I can get 2 squares of this for under $15
There's a West Marine 10 minutes from my office, and it is always fun to look around anyway..
Don
Old 11-04-2014, 03:05 PM   #12
DJW
DJW's Avatar
2004 25' Safari
Follow up report- Bought 2 of the Dri-Dek panels. $13.xx. Cut to fit- easy with a pair of tin snips. Fits and works perfectly, even color coordinated.
Thanks all,
Don
2006 Bambi Quik Silver 16ft Coloradobus Shocks 0 05-31-2014 12:55 PM
Bambi propane tank rack mod. lacosta LP Gas, Piping, Tanks & Regulators 7 11-14-2009 05:34 PM
A/S entry mat bjstewart1 Upholstery, Blinds, Walls & Interior Finishes 30 06-29-2007 02:11 AM
Awning mat azflycaster Exterior Restoration Forum 20 02-12-2007 05:20 PM
