Old 01-24-2008, 09:50 AM   #1
Lothlorian's Avatar
Loganville , Georgia
Propane tank, lines, regulator question
If you were to buy an orginal 1973 airstream and you had the orginal tanks, lines and regulator on it what would you change if everything was working? Should I just leave it, or is it wise to update? What should I add or change?
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 01-24-2008, 10:01 AM   #2
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
Check the date on your tanks. I owned my 74 almost two years before I discovered the tanks were stamped 79. Still pretty old however. The date can be found on the upper handle of the tank.
bimpy is offline   Reply With Quote
Old 01-24-2008, 10:04 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Rubber hoses should be replaced, regulator should be looked at closely, and probably replaced. If the tanks are aluminum, take them in and have them recertified, it is much cheaper than buying new replacements.
Copper lines should be replaced if they show signs of wear or damage.
Old 01-24-2008, 10:27 AM   #4
Central , Mississippi
Originally Posted by overlander63
Rubber hoses should be replaced, ....
Go ahead and replace the rubber and get the new style ends. Any RV Dealer will have the parts. One of mine sprung a leak and empytied the tank while on the road. The cost of the lost propane was more than a replacement hose . One failure mode of the regulators is, when bad, they will allow a full tank to discharge into the empty tank if both valves are open. This results in no warning until both tanks are empty if you run with both valves open.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-24-2008, 10:34 AM   #5
Kajtek1's Avatar
1965 22' Safari
Orinda , California
The overfill protection valve requirements are about 5 years old. All tanks not equipped with them will not be filled (legally) with propane. That apply to portable tanks, not the commercial type build-in in motorhomes.
New tanks also have different, more convenient couplers.
I just bought new switchover valve with regulator at Camping World for about $50.
Kajtek1 is offline   Reply With Quote
Old 01-24-2008, 11:06 AM   #6
Lothlorian's Avatar
Thanks a bunch!
Before I bought the trailer I tested the stove and the propane heater by the door. Everything worked. I would like to keep the tanks and upgrade the hoses and regulator. I did not know there was a legal issue about parts.
SIU Bound
Old 02-04-2008, 07:31 PM   #7
azfiredog300's Avatar
Surprise , Arizona
I just had the old valves on my 40lb alumnum tanks replaced with the new OPV valve and also had them both certified for $69.00 total. Much cheaper then buying the new tanks
azfiredog300 is offline   Reply With Quote
Old 02-04-2008, 08:38 PM   #8
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Modern legal valves are easy to spot. They have triangular valve handles, that is, three lobe.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 02-05-2008, 03:53 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I never had my tanks "recertified". Maybe that is a state to state requirement. No way to get around new OPD valves. I never replaced the copper lines from the tank to the regulator and my old regulator still works fine. There are new lines that hand tighten that are more convenient. An old regulator can have a bad diaphram that won't give you the right pressure.
Old 02-06-2008, 10:29 AM   #10
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
My 40lb Worthington aluminum tanks have a gasket on the inside of the valve connection - and one of them is worn and leaking. Are these a common replacement part? Have any of you replaced them?
Thanks - Pat.
pmclemore is offline   Reply With Quote
Old 02-06-2008, 11:04 AM   #11
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I took my tanks in for recertification at a major wholesale distributor and the guys saw the new style valves and just filled them, I had asked for the stamp style testing so some backwoods vendor would not refuse me and afterwards found they used a small grinder to free-hand engrave something like VIP-date (visual inspection passed + date) so be wary what level of 'certification' they actually are providing BEFORE you let them take possession of your Worthingtons!
Old 02-06-2008, 11:16 AM   #12
Surprise , Arizona
my recert is a metal tape with a pen markd date. The tanks i had revalved were the 40 lb worthington so its prety easy and cheap
Old 02-06-2008, 12:13 PM   #13
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Overfill protection valves (OPD) are NOT required on HORIZONTAL tanks of 4 to 40 lbs made before 1 Oct 1998 and are labeld that they do not have OPD valve installed.Ref Home - National Propane Gas Association under issues. Some Argosy and Airstreams TT made in the 1980's and early 1990's use horizontal tanks.
Certification/recertification is by State law.In most States new tanks are good for 12 years from date made and recertification is good for 5 years and can be recertifed as often as tank passes test.But this is a State by State issue so check your State and any State that you may need your tank filled in.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 02-25-2008, 09:43 PM   #14
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
I have a 1981 that I've never had checked for leaks. I did upgrade the tanks last year to the new valves since I couldn't get them filled otherwise, and yes it was much less expensive then buying new tanks. Everything that runs on propane has worked very well since we've had it. What would be the easiest way to have the system checked? Do they sell a cheap leak detector, or do most people have the system professionally checked?
Overlander: You mentioned replacing the rubber hoses. Are these only the hoses that run from the tank to the regulator that should be replaced?
Charlie
Pacerized is offline   Reply With Quote
propane regulator advice needed goransons LP Gas, Piping, Tanks & Regulators 34 10-31-2017 06:13 PM
Can a propane generator freeze the regulator? richschafer LP Gas, Piping, Tanks & Regulators 4 07-10-2007 05:33 PM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 03:45 PM
propane lines airtim LP Gas, Piping, Tanks & Regulators 18 03-26-2005 07:38 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
