Old 04-07-2003, 09:12 PM   #1
1978 31' Excella 500
1948 22' Liner
Costa Mesa , California
Question Propane tank gauge
Does anyone know if you can get the parts to make the propane tanks display lights work inside the trailer? My trailer has display lights inside the cabnet above the stove but there is nothing on the tanks to send a signal to the display panel. The display panel works just fine.
Thanks for any help!
31' 1978 Exella
Jim Miller is offline   Reply With Quote
Old 04-07-2003, 09:17 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If you have not changed out your valves to OPD you should be able to get them done with sending units. If you are looking to replace the tanks, you can buy them already setup. there is a single blade connector to connect the gauge on the tank to the monitor panel.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-07-2003, 09:29 PM   #3
1948 22' Liner
Thanks Brett!
I have not changed anything on the tanks. When I got the trailer 15 years ago it did not have the sending units. It's not a big deal to have the display work but I am currently polishing the outside and thought it would be fun to have everything working. I'm probibly getting carried away but do you know where to get these sending units?
My next thing will be the door bell....I know I'm nuts?
Thanks for the help!
Old 04-07-2003, 09:46 PM   #4
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
You will be required to change the existing POL type valves over to OPD style before they can be refilled at the local LP place.
There should be a local company that can do this for you. Call around beacuse prices vary widely. Also be aware that the Alumimum tanks require a difffrent OPD than the Steel ones do. I belive both can be fittted with the gauge, but your LP guy can tell you for sure.
As to the being nuts, that is a requirement to own one in my book. I drove my motorhome almost 1000 miles round trip between thursday night and sunday night to get together with other forum members for 2 days. Nuts, yes. but worth every penny and taking time off from work to get together with others that share our affliction.
Brett G
Old 04-09-2003, 08:32 AM   #5
1948 22' Liner
Thanks Brett! I'll check with LP guy.
Old 04-09-2003, 11:05 AM   #6
Make sure when you get the OPD valves to check the stamping on upper part of shaft, as 99% of dealers will sell you valves for steel, not aluminium tanks.
correct OPD tubes length for aluminium are:
#20 _ 4.8
#30 _ 5.8 (not 6" as indicated on WBCCI article)
#40 _ 7.0
femuse is offline   Reply With Quote
Old 04-09-2003, 04:25 PM   #7
1948 22' Liner
Thanks!
Propane Tank Cover tmeagle1 LP Gas, Piping, Tanks & Regulators 6 03-04-2004 07:30 PM
Propane Tank Emptying & Certifying drober05 LP Gas, Piping, Tanks & Regulators 1 11-03-2003 11:35 AM
Propane tank cover.... drboyd LP Gas, Piping, Tanks & Regulators 2 07-29-2003 03:42 PM
Propane tank charlief1317 Airstream Motorhome Forums 14 01-04-2003 08:00 PM
