I have not. There are three things to watch:
1) Many propane exchange services short fill the cylinders which is both inconvenient and uneconomical.
2) Typically the propane exchange places only work with 20 pound cylinders. I believe your trailer has 30 pound cylinders.
3) Typically exchange services will not provide you with an aluminum cylinder. I believe your trailer has steel cylinders unless you paid extra to get aluminum ones, but that's something to keep in mind.
We typically use 2 cylinders a year and usually just get them filled when we happen across a campground or gas station that does it. My storage place fills cylinders, too, and there are a couple of places on the road from my house to the storage place.
