Old 12-13-2007, 06:21 PM   #29
2007 25' Safari FB SE
Truckee , California
Smile
Originally Posted by hazegrey
I think I finally figured out how to post the picture.
Hazegray, brilliant solution, thanks (tryin out the quote thing )
fred
flyfishfred is offline   Reply With Quote
Old 12-13-2007, 06:51 PM   #30
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
These are all great solutions. I myself was kind of hoping to figure out some way to simply lock the tank cover latch. To me it stops folks from messing around with the tank valves. In retrospect though, in my case mine is stored indoors, and the odds are low that someone may even mess with the tanks in the first place, but hey, if but nothin' else, I may just get those dual locks that I saw here...quick, cheap and easy.
Old 12-14-2007, 02:26 PM   #31
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Lewster
Where can I get one of those lock for my propane mounting brakett/threaded rod. I also have the alum. wingnut.
Roger
Mikethefixit is offline   Reply With Quote
Old 12-27-2007, 02:01 PM   #32
wagnerda's Avatar
2006 19' Safari SE
Central Part , Maryland
Thanks "2dabeach"....
I just finished up installing my tank lock based on your idea and it works great !!!!
Photo attached as I know people always like to see...
Also, the white thing is my remote temp/humidity sensor that is mounted with velcro inside the propane tank cover. It has been riding there for over 15,000 miles and hasn't fallen off yet so I guess it is stuck on good. I never remove it when driving.
Couple other pics are the inside unit for the temp/humidity meter which is also just put on with velcro onto the wood cabinet above the stereo.
Nice and warm here today in Maryland -- 61 . 5 degrees and 45% humidity - so I am taking care of a few maintenance items before hitting the road next week for Florida.
anyway, thanks again for the lock idea.
regards, Dave
ID:	51597   Click image for larger version
Dave&Shari Wagner
2006 Bambi SE,
2008 Ford F350 Diesel 4x4
AIR#23096
" I am lost and have gone Airstreaming to find myself, If I should return before I get back, please ask me to wait..."
wagnerda is offline   Reply With Quote
Old 02-08-2015, 02:17 PM   #33
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I don't know if someone would want your propane tanks this bad or not, but it looks like some of the lock setups could be defeated by just unscrewing the rod instead with a pair of pliers. If and when my lock setup finally arrives, I'm planning to bend the bottom end of the new stainless allthread rod in a "U" at the bottom, so it can't easily be unscrewed "out from under" the locking nut.
I'll also be putting a fairly loose piece of stainless tubing over the allthread, to further discourage cutting, at least in the middle of the rod.
If someone needs a tank of propane bad enough to lay in the dirt under the trailer and unbend the rod - well, I guess they can have it.
Old 02-09-2015, 05:28 PM   #34
2014 27' Flying Cloud
Stowe , Vermont
I just purchased a Fortress GasLock from Colonial AS in NJ (called in order) I researched it and it looks like a solid piece of equipment that locks the tanks - not the cover. Colonial sells the Fortress that is made for AS. Most thieves are looking for easy scores, so this offers a real challenge. Hopefully they will move on to an easier target. It is in the $60 range. When my tanks were stolen, it cost way more to replace the tanks, pay for purging and paying for 2, 30 gallon fills.
VT Wanderer is offline   Reply With Quote
Old 02-09-2015, 06:01 PM   #35
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Originally Posted by lewster View Post
Just as soon as I get back to FL. I'm pulling out at 0:dawn:30 tomorrow morning..........BACK ON THE ROAD AGAIN!
At least this is just a little hop........only 2000 miles to SW FL.
Hey!
Where in FL? Are you going to Alumaflamingo? Our WBCCI Suncoast Unit will be there as a group. Looking forward to it. We live a short distance and always enjoyed Sarasota.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Propane tank cover walter1 LP Gas, Piping, Tanks & Regulators 9 03-14-2007 11:08 PM
Need propane tank cover and front rock guard! cobra93 Rock Guards, Segment & Window Protectors 8 08-11-2006 10:10 PM
Propane Tank Cover tmeagle1 LP Gas, Piping, Tanks & Regulators 6 03-04-2004 07:30 PM
Propane tank cover.... drboyd LP Gas, Piping, Tanks & Regulators 2 07-29-2003 03:42 PM
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
