Old 10-11-2007, 09:06 AM   #15
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Originally Posted by walter1
Thanks for the ideas. 2dabeach’s lock setup looks great. Simple form following function.
My "wingnut" is a ‘70s solid cast aluminum piece.
This gets me engineering. For now the tanks are cable locked.
What is the white bracket inside the box under the cross member for?
Would like to see photos of what Lew’s lock setup looks like.
Thanks for the thoughts
Walter
Walter
The white bracket is the mounting plate that holds the outdoor sensor for our indoor/outdoor wireless thermometer mounted inside our trailer.
2dabeach is offline   Reply With Quote
Old 10-11-2007, 10:22 AM   #16
extiger's Avatar
2011 30' Classic
Kingwood , Texas
What a clever place to put the sensor! Does it read true there or does enclosing it in the box raise the temperature?
extiger is offline   Reply With Quote
Old 10-11-2007, 12:43 PM   #17
2dabeach's Avatar
Smile
Extiger
The temperature may run a little high if the trailer is parked where the sun is hitting the front of the tank cover. We haven’t noticed any unusual readings on the outside temperature while living in the trailer for 3+ months. The main thing is that the unit is out of the way and is keep dry. The holder is attached to the cover with Velcro and we take the sensor out of the holder when we're traveling.
Old 10-11-2007, 06:46 PM   #18
Haze Grey & Underway
2008 27' Safari FB SE
Cedar Crest , New Mexico
Just another take on a low tech locking system
I just got my airstream and have not road tested the pictured system. I used these locks on my old trailer to lock the tanks and looks like they might work here as well. By the way the two locks are keyed the same and the black is just electrical tape for padding/insulation.
Sorry, I do not have the photo on the net so I am not sure how to attach it. Basically I took two long shank locks and hooked them through one another and then one on each side of the threaded upright. Advantage is no drilling required and fairly cheap. R/ Dave
hazegrey is offline   Reply With Quote
Old 10-11-2007, 08:21 PM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Now Thats A Simple Solution
Originally Posted by 2dabeach
I solved the problem on my 2007 Safari by drilling a hole through the steel wingnut and the cover's aluminum cross-member and placing a padlock through the holes. Picture attached.
THAT WORKS FOR ME!!!
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 10-11-2007, 09:19 PM   #20
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I wish my tanks were set up that way. My "wing" nut sits flush against the top. no room for the lock.
Michelle TAC MT-0
Sarah, Snowball
Old 10-12-2007, 02:46 PM   #21
Picture of the two lock solution
I think I finally figured out how to post the picture.
Old 10-12-2007, 03:31 PM   #22
walter1's Avatar
1964 22' Safari
Foresthill , California
Nice, thanks for photos.
Simple, effective.
Slowing them down long enough to alert Mr Smith and Mr Wesson is just what I’m looking for.
walter1 is offline   Reply With Quote
Old 11-25-2007, 05:24 PM   #23
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Lewster was nice enough to send me one of these locks after he landed in Florida. We stopped by the trailer today and I installed it. Since I am not a certified RV tech like Lew, my install time was not 5 seconds, but more like 2 minutes. You remove one nut, install the arm under the nut and lock the cover on.
Thanks again Lew!
ID:	49886   Click image for larger version
Richard
Old 11-25-2007, 07:17 PM   #24
lewster's Avatar
Naples, FL , Hood River, OR
My Pleasure!
Old 11-26-2007, 06:54 AM   #25
Denis4x4's Avatar
Durango , Colorado
If you look at any RV, including SOB's, access to the propane tanks is NOT LOCKED! This is a safety issue. Locking the tank cover is not a good idea.
Denis4x4 is offline   Reply With Quote
Old 11-26-2007, 08:01 AM   #26
2002 25' Safari
Dewey , Arizona
Images: 62
This is not a cover lock. It locks the tanks. They can stillbe turned off.
Richard
Old 11-26-2007, 08:07 AM   #27
richinny's Avatar
2011 34' Classic
i'd think that most locks are easily defeatable by any emergency crew or someone clearly not making a "service call" to remove the tanks.
Ricky
Old 11-26-2007, 11:08 AM   #28
wagnerda's Avatar
2006 19' Safari SE
Central Part , Maryland
Thanks "2dabeach", I have been wanting a way to easily lock the tanks and yours looks nice and simple. I now have a project coming up to drill a hole thru mine like in your photo and install a lock.
One thing about locks is several years ago I went to a real hardware store - I think ACE hardware, and bought a whole box of Master padlocks all "keyed-alike". They have really come in handy over the years with one key fitting just about everything I have. There must have been about 18 or so locks in that box.
Anyway, not sure if places like Lowes or Home Depot sells keyed-alike locks, but "real" hardware stores do and that really makes things convenient.
regards...
Dave&Shari Wagner
2006 Bambi SE,
2008 Ford F350 Diesel 4x4
AIR#23096
" I am lost and have gone Airstreaming to find myself, If I should return before I get back, please ask me to wait..."
wagnerda is offline   Reply With Quote
Propane tank cover walter1 LP Gas, Piping, Tanks & Regulators 9 03-14-2007 11:08 PM
Need propane tank cover and front rock guard! cobra93 Rock Guards, Segment & Window Protectors 8 08-11-2006 10:10 PM
Propane Tank Cover tmeagle1 LP Gas, Piping, Tanks & Regulators 6 03-04-2004 07:30 PM
Propane tank cover.... drboyd LP Gas, Piping, Tanks & Regulators 2 07-29-2003 03:42 PM
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
