Old 09-12-2011, 07:35 PM   #1
Hansom-Man's Avatar
2009 23' FB Flying Cloud
The Woodlands , Texas
Propane tank bracket / holder
I'm prepping the "Glamshell" for our next road trip & fixing a couple of issues left behind from the original owner who jack-knifed the trailer backing in and mangled the tank holder/storage assembly.
I've managed to reshape the aluminum shroud & rock guard reasonably well. However, I cannot bend the storage tray at all. This would be the tray with the threaded stem that the tanks rest on that is bolted to the A frame.
Is this a fairly standard part, or something that's been customized by AS? I've seen these listed at some of of the local RV dealers in white & wondering if I can use one of these and paint it. Or do I just need to order one from AS?
Hansom-Man is offline   Reply With Quote
Old 09-12-2011, 07:50 PM   #2
Originally Posted by Hansom-Man View Post
I'm
You cannot order parts from the factory, except through a dealer.
That is a franchise agreement Airstream has had with it's dealers for over a half a century.
You can however, order some small things from the Airstream store, who cannot sell the basic repair parts.
Old 09-12-2011, 08:05 PM   #3
Hansom-Man's Avatar
OK is this something I should order from an AS dealer or purchase an off the shelf / SOB and paint it?
Not trying to be a smartalec or anything, I just want to get it done while I've got everything apart.
Cheers
Old 09-12-2011, 08:12 PM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Not sure exactly what the newer tank holder looks like but if it looks like the one all the SOB's use , might as well use it. It'll do the same thing.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 09-12-2011, 09:07 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Cheers
Hi, I just did a quick search for RV propane brackets and got a site called Tweetys; They show a propane bracket just like the one on my Safari. Generic item, not Airstream specific.
I just found this one on E-bay.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-12-2011, 11:16 PM   #6
Cheers
Get it locally, if you can.
Propane tank cover desertair27 LP Gas, Piping, Tanks & Regulators 20 09-16-2011 04:36 AM
Auxilary Fuel (gasoline) Tank? DGJackson 1970-79 Tradewind 3 08-18-2011 10:44 PM
30# Propane Tank Cover(s) Success101 LP Gas, Piping, Tanks & Regulators 2 08-09-2011 03:17 PM
Propane tank Alfresco LP Gas, Piping, Tanks & Regulators 9 06-29-2011 04:25 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
