Old 06-28-2011, 04:51 PM   #1
Alfresco's Avatar
2010 23' International
Sisters , Oregon
Propane tank
I attempted to obtain the first refill of a propane tank from our 2010 23' Int'l but the tank would not accept refilling. The attendant said possibly the inside float valve was not functioning. The local propane supplier (Ed Staub) said if I drive 23 miles to their facility they can replace the valve for $25.- Have others had this problem?
Alfresco is offline   Reply With Quote
Old 06-28-2011, 04:56 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
It's probably fine. I'm guessing operator error. If you take it to their main plant someone can probably figure it out without replacing anything.
Old 06-28-2011, 05:47 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Occasionally, I run across cylinders that have so much air expansion within that our pump won't hardly push propane in. I have to bleed off some of the air, then fill the cylinder. Even more common is to find folks with full or nearly full cylinders that "won't work." Same problem: Too much air expansion within. I bleed some of the air and hand the tank back to them. (Typically, these are folks who had the cylinders filled at very different elevations/temperatures from here.)
Lynn
WBCCI 21043
Old 06-28-2011, 05:56 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Did they vent while filling? there is a screw on the side of the valve.
Michelle TAC MT-0
Sarah, Snowball
Old 06-28-2011, 06:03 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Michelle, in some states (maybe many?), venting during filling is either strongly discouraged or outright forbidden. It allows too much propane to escape into the atmosphere.
Lynn
WBCCI 21043
Old 06-28-2011, 06:15 PM   #6
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Try picking the tank up maybe a foot or so off the ground then whack it back down rather hard. Sometimes the safety float thing hangs up inside preventing filling. Might take several whacks. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 06-28-2011, 07:35 PM   #7
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Once I carried mine to the local Butane dealer and had it laying horizontal (not recommended) in the back of the minivan. The mechanism got temporarily stuck in the failsafe position. The aforementioned vertical bounce on the ground set it all straight and life was good again. When they first started filling the new style tanks they sometimes opened the fill valve too quickly and that seemed to trigger a failure mode. Since then they always open the valve slowly and the tank fills normally.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-28-2011, 11:36 PM   #8
Alfresco's Avatar
Sisters , Oregon
alfresco
Two different suppliers were unable to fill the tank. Both had opened the vent screw. I will try the downward thrust motion to loosen the float valve.That makes the most sense as to cause.
Old 06-29-2011, 06:40 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
If it won't come unstuck from the banging, it's not that bad. Changing out OPD valves on *steel cylinders is a fairly quick-and-dirty job if they have some means to hold the cylinder stationary while they screw out/in the valve. Since valve change-out has been a fairly common job for the last 9 years, I suspect most dealers have figured out some means to hold cylinders.
*Steel. If you have aluminum cylinders, they'll need to take care to select the proper replacement valve. Aluminum cylinders are a bit taller than the corresponding steel cylinders, requiring a lengthier valve.
Lynn
WBCCI 21043
Old 06-29-2011, 04:25 PM   #10
Alfresco's Avatar
Sisters , Oregon
Banging the tank on the ground did finally free up the interior float valve. Thanks for the input
propane gas leak (rotten eggs) 2010 International stench wendywoods LP Gas, Piping, Tanks & Regulators 20 12-01-2011 02:34 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 01:07 PM
