Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 05-09-2018, 07:39 PM   #1
Villwocksbj's Avatar
2014 23' International
San Juan Capistrano , California
Propane smell around my dual tank cover
I’ve noted a propane odor around my dual tanks when both tanks are open. I’ve checked for tieghtness on tank hose and both are tieght. Could this be a regulator issue?
Villwocksbj is offline   Reply With Quote
Old 05-09-2018, 09:31 PM   #2
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Is this apparent after having one of the tanks filled? I notice sometimes slight venting at the end of the valve when I have a tank filled and it sits in the sun. I just switch over to that tank to use it to draw it down faster. Sometimes the propane filler overfills it a little.
Kelvin
Old 05-10-2018, 04:27 AM   #3
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Vill-
I recently replaced the pigtails on our 2014 coach, the short LP hoses that go from the regulator/tank selector to the tanks. Like you, I had a slight leak/smell of propane, and the new hoses cured it. The originals were probably due for replacement anyhow.
I strongly recommend that you find a real gas company store in your area (one that sells parts, gas appliances, etc.) and purchase USA-made hoses from them. The cheapy China hoses available are just that - cheap. They don't seal nor hold up well. Also, make sure you use gas-rated pipe dope or tape on all the NPT threads....... One last item, make sure your LP quick connect for a remote LP connection is sealed up and the valve hasn't opened from vibration.
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 05-10-2018, 05:44 AM   #4
Chelsea , Maine
Spray it with water that has a little dish soap in it and look for bubbles.
I had a regulator leaking once, all around the body of it, where the two halves were crimped together. It doesn’t have to be a fitting...
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 05-10-2018, 06:34 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
What JMynes said.
Bob Martel
WBCCI# 5766
Old 05-10-2018, 06:53 AM   #6
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
What Jmynes said X2!
Plus spray down every connection you can find under and around the Airstream. I found a major leak at the refrigerator connection. I was noticing that my pressure indicator would leak down to empty overnight with the tanks off and with no propane use. So I pressurized the lines and sprayed soapy water on joints until I found the leak. I also found a leaks on two cheap propane hoses with soapy water. You may be surprised by the leaks you will discover.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 05-10-2018, 09:57 AM   #7
ZoominC6's Avatar
2004 30' Classic Slideout
2021 33FB Classic
Colleyville , TX
We had the same problem on our 2004 so the last time we had it in for service items we added this issue to the punch list. New regulator and hoses! Problem solved.
Happy trails.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 05-10-2018, 10:34 AM   #8
2011 27' FB Classic
Masontown , West Virginia
All of the above is good, but I would re-enforce ShinyPete's suggestion to find a "real" gas provider to make new pigtails if that is the problem - - it is Number One on my list, having just replaced mine.
Bill
Bill & Dorothy Reeves
2011 27FB
2016 F250 6.2L
TAC # WV-2
MountaineerStreamer is offline   Reply With Quote
Old 05-11-2018, 11:30 AM   #9
2015 25' FB Flying Cloud
Sandy , Utah
I had the same problem. It was the Regulator leaking where the two parts were pressed together. The soap and water method mentioned above is how I found it.
rocco52 is offline   Reply With Quote
30lb aluminum dual propane tank cover Green123 Airstream Classifieds 2 07-08-2020 10:59 AM
Propane smell in oven ! Dan S All Argosy Trailers 12 10-21-2007 11:17 AM
Is it normal to smell propane? pamelake Refrigerators 31 06-15-2007 04:41 PM
Propane smell jimmieanna LP Gas, Piping, Tanks & Regulators 19 08-19-2006 02:24 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
