Old 01-01-2015, 12:26 AM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Propane Regulator - Which to use with SeeLevel 2 System?
Ok, full disclosure here, I'm REALLY green when it comes to this kind of stuff, but I'm learning a lot as we renovate our '79 Excella. The topic today is what to do about the propane system...
We're using the SeeLevel 2 Tank Monitoring system (http://amzn.com/B004A34I10) which has the ability to display the remaining level of propane in percent. Our Excella has 2 x 40lb propane tanks connected by a regulator which supplies fuel to all the gas-operated things in the camper.
With all that being said, my question is this: what do I need to be able to monitor the tank levels using the SeeLevel 2 panel? Is there supposed to be a sensor on each tank? Or is there supposed to be a sensor on the regulator to report the percent full? I see neither in my current setup, so I'll need to buy something to make this work, just not sure what.
1. Do I need something like this Manchester Sender Unit? http://amzn.com/B003D3WPGS. If so, when one tank is empty and I switch to the other, how would the SeeLevel system know to begin monitoring the 2nd tank? Would I have to manually switch the sensor cable from one to another?
2. Or maybe I need a sensor built into the regulator; something like this? Propane Regulator Valves on Sale - PPL Motor Homes. I don't think this exact unit would work for my application since the "sensor" they mention sounds like it's just a light on top of the device itself.
Any advice, or pictures of your setup (with remote level monitoring) would be appreciated, thank you!
trekerboy is offline   Reply With Quote
SeeLevel Tank Monitors Okay? dbj216 Waste Systems, Tanks & Totes 16 07-13-2015 09:18 PM
Tank side wall height for SeeLevel Sensors? mtntime Plumbing - Systems & Fixtures 1 06-15-2012 10:26 AM
SeeLevel II display not working johnandlauri General Repair Forum 0 09-17-2010 08:09 AM
Seelevel Monitoring Systems rickandsandi Waste Systems, Tanks & Totes 3 10-13-2009 07:48 AM
SeeLevel Gauges 68 Overlander Commercial Listings 11 07-11-2007 11:12 AM
