Old 03-07-2009, 09:07 AM   #15
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Perfect!
Good job! I particularly like the bottom mount shown.
Bad news on the one that shows the Propane bottle mounted inside the closed box WITH the battery, solenoid, switches and electrical controls. Good news is that they caught the problem before the fire ball.
Thanks!!!
Old 03-07-2009, 09:31 AM   #16
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When we had a pop up trailer it had a single 20# propane tank. The regulator was attached to the fitting that went into the tank. It was a very simple setup and worked well for the many years we owned the trailer.
Richard
Old 03-07-2009, 09:40 AM   #17
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
a clean vintage look type
Richard,
Yes on the regulator to the bottle. My big problem was, is, the bottle mount to the pipe frame and all that that entails. I want a clean look thats solid.
Old 03-07-2009, 09:52 AM   #18
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I too liked that idea best. I think I would try to make the bottom ring round to give it a vintage look and cleaner appearance. Good luck.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-07-2009, 10:10 AM   #19
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Strange setup
We just acquired an '83 27' Excella. The automatic change over regulator was mounted about a foot above the tongue inside the cover, with a hole in the front of the cover to see the "flag" when a bottle runs dry. The hole is located behind the tongue jack, so the "flag was hidden from sight. It looked like a factory installation. The PO just lived with the situation. He let a bottle run dry, then changed over to the other, not using the automatic feature of the regulator. I moved the regulator up to the top of the bottles and bought a new hose at the local RV supply. While I was at it I put on a new regulator and upper supply hoses.
Will all be better now.
propane regulator advice needed goransons LP Gas, Piping, Tanks & Regulators 34 10-31-2017 06:13 PM
Regulator Mounting? dnrtheil LP Gas, Piping, Tanks & Regulators 2 04-03-2008 11:27 AM
Propane tank, lines, regulator question Lothlorian LP Gas, Piping, Tanks & Regulators 16 02-27-2008 09:02 PM
tv mounting katsix Audio, Video & TV 4 01-01-2008 08:01 AM
Can a propane generator freeze the regulator? richschafer LP Gas, Piping, Tanks & Regulators 4 07-10-2007 05:33 PM
