Old 01-04-2008, 09:31 PM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Question propane regulator advice needed
So I posted this as part of our 69 trailer pics thread but didn't get any suggestions so I thought I'd post it in the propane area and hope that someone can help.
First and foremost we're concerned about safety, but also want to not throw away money or good parts. We have all new appliances coming, RM2562 Fridge, Suburban 22" range and 10 gallon water heater.
I have 2 new tanks installed ready to go. With the shutoff valves at each appliance off I've pressure tested the lines with the regulator removed and no leaks over a 12 hour period. Once the appliances arrive and I get them installed, I'll want to get the system pressurized with a regulator and test everything out.
The propane system was already disassembled somewhat due to the po's mid gut job. The regulator I know nothing about, a Marshall model 230. Shows signs of being outside (rust on the screw heads, discoloring of plastic parts). Unsure if it works or for that matter how to test it to see if it works other than hooking it up. New hoses are in order either way. Is this worth testing/keeping or should I replace with a new model? I don't want to damage the new appliances in any way. Also if replacement is necessary what is a good model/brand to go with?
I really appreciate your input.
Here's a photo of the regulator that came with the trailer:
Name:	IMG_1430 (Small).JPG
goransons is offline   Reply With Quote
Old 01-04-2008, 09:45 PM   #2
2002 19' Bambi
Lafayette , California
You can get a new Marshall regulator with automatic changeover (between 2 tanks) for for about $40 to $60. Regulator problems are no fun and the cost of a new regulator is low enough that trying to repair an old one is probably a waste.
Tim A. is offline   Reply With Quote
Old 01-04-2008, 10:23 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I think Tim gave good advice. It's worth the money for peace of mind.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-05-2008, 03:22 AM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Original look
I replaced mine. Compared to your other upgrades a new regulator is inexpensive. I got mine here.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-05-2008, 06:01 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Regulators are generally NOT field serviceable. That said, when you throw in the relatively low cost of a new part into the overall safety equation, it makes no sense to mess with an old one.
I have been perticularly impressed with the new Cavagna #70-A-190-0016, 2-stage regulator. They are well made and have a very large window at the top to easily see the fill conditions of your tanks, and a lge knob to switch tanks that is easy to use. They retail for about $53.
Old 01-05-2008, 06:23 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Lew, I threw that brand & number in Google to take a look. Looks like it's on sale for $40.31 - Automatic Changeover LP Regulator
5 meter Langford Nahanni
Old 01-05-2008, 07:04 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
An endorsement
That regulator was on Bertha when when got the trailer, it works as intended, with no problems. If and when we need another one, I'll probably replace it with another just like it.
Old 01-05-2008, 07:23 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The problem with old regulators is the diaphragm gets stiff and gas pressure is reduced. You can make a home made manometer with a U shaped tube with one end hooked up to the regulator. As you apply gas pressure you will see a difference in the water levels. The level on the pressurized side will go down and the unpressured size will go up. With a good regulator you should get a difference of about 11" water column pressure.
Old 01-05-2008, 10:10 AM   #9
goransons's Avatar
1963 22' Safari
I definately like that readout better than others I've seen. I just thought I'd ask because after seeing vent handles selling for 60 bucks a pair on ebay I didn't want to toss a regulator that might be worth more than the replacement and still work fine, but it sounds like it should be replaced.
Price isn't bad, but as you all probably know better than us, it seems the AS gets finished must slower than our budget does!
Old 01-05-2008, 11:41 AM   #10
Geezer
1991 25' Excella
Sapulpa , Oklahoma
Question Pressure adjustment
Anyway to learn how to adjust pressure while in transit? I have a new regulator but no manual. I have a new inverter but no manual. I guess I need a new service man.
My problem was that I assume that I am asking dumb questions and the service people seem to resent questions. The problem of course is that when you are on the road you are on your own.
LRPorter is offline   Reply With Quote
Old 01-05-2008, 05:54 PM   #11
lewster's Avatar
Bob,
Nice detective work.........THAT'S THE ONE!!!!
LR,
No service person should cop an attitude, espcially when you are paying the bill!!!!!! Many times, my clients watch me when I work....not because they don't trust me, but because they are truly interested in learning about the particular component. I even provide a runnng commentary!
That said, LP regulators are not difficult to adjust, but they should be set with at least a 50% propane load and adjusted to the industry standard of 11" water guage (WG) (the term 'water column' or WC, was replaced with WG several yers ago due to the confusion it causes when you look at an LP tank and see 'WC on it. This WC refers to the water capacity of the particular LP tank and specifies it's lquid capacity when filling it......see why it's confusing and was changed?)
Anyway, I would never adjust any regulator for any LP appliance without an accurate manometer to measure the LP pressure. ANYONE who calls themselves an RV tech should be properly equipped and trained to make this adjustment for you.
Basically, there is a cover over an adjusting screw (usually a hex) on top of the diaphram. The screw changes the pre-set pressure on the diaphram.......thus adjusting th LP pressure that it allows to pass thru to the system. You must be very careful when adjusting this screw, as over tightening will result in damage to the diaphram.
Hope this helps!
Old 09-22-2008, 12:33 AM   #12
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
Originally Posted by lewster View Post
Bob,
LR,
Hope this helps!
Lew, it seems that the Marshal Regulators used by Airstream and many others are not set from the factory to the recommended 11 inches of water gauge. I have tested the pressure of six different Airstreams, three had replacement Marshall regulators and three were original with the Airstream and typically have found the pressure to be 8 to 9 inches WG using a manometer that I constructed. None were more than four years old. Four of the six would not adjust to the 11 inches, stopping at 10 to 10 1/2 inches WG, of these four three were new replacements!
Have you seen any trend in Marshall regulators not adjusting to the industry standard. Our friends back east might not have a problem with the lower pressures but here in California with 100 degree outside temperatures it can mean the difference between 50 degrees inside the refrig vs 40 degrees.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 09-22-2008, 10:23 PM   #13
lewster's Avatar
Hey Don,
I haven't noticed any 'trend' yet.......but I'll keep a look out of I get a rash of low output regulators.
Old 09-23-2008, 07:25 AM   #14
mandolindave's Avatar
I can't remember the name of manufacturer.
I had the big old original heavy duty regulator on my 1973 trailer. It looked like it belonged on a submarine. I thought that it was time for a new one. Andy at Inland shipped me an exact replacement. It looks cool. It gives me piece of mind. I had heard too many scary stories about the Marshalls.
As I recall, it was well over $100. But my daughter stays in my camper sometimes. Some may think that I am foolish for spending the money. Piece of mind ??????? Priceless. Just an opinion here, as I am not an expert by any stretch of the imagination.
mandolindave is offline   Reply With Quote
Advice needed on a 1999 BLACK Chevy Suburban, K1500 XpeditionsTV Tow Vehicles 16 10-02-2007 09:34 PM
Can a propane generator freeze the regulator? richschafer LP Gas, Piping, Tanks & Regulators 4 07-10-2007 05:33 PM
Exterior advice needed brenda02 Clearcoat, Exterior Paint & Trim 6 03-06-2007 09:31 AM
Hello, and advice needed dirty old man Our Community 3 04-23-2004 10:22 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
