Old 10-19-2003, 07:01 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Propane refill question
Our one tank needs refilling; must I take off the tank? I don't think I can lift it easily. On our MH the tank was not removable and was fillable.
Does the flip valve or whatever you call that thing that changes which tank is being used flip over to the other tank automatically?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 10-19-2003, 07:23 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If you are in a park that offers propane sevice the truck will come to you. The other option is to tow the trailer to the propane place and have the "kid" lift it off and back on.
I would reccomend turning off the gas on both tanks when you remove the tank for refill. The switchover regulator is suppose to block off the gas, but I have seen them leak.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-19-2003, 07:39 PM   #3
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
I would say shut both gas valves off then take your bottle cover off then you can take your bottle off. It can be done in less then 5 minutes. Once a bottle is empty they weigh next to nothing..
As THK has said I would reccomend shutting the bottle off that remains. if you are worried about your LP on fridge it will be ok for up to 5 hours in the right conditions. even easier turn it to A/C.
JP
JPAIRSTREAM is offline   Reply With Quote
Propane Powered EU2000i? Pick Generators & Solar Power 8 04-09-2016 06:36 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
Propane tanks question Swingking LP Gas, Piping, Tanks & Regulators 8 10-22-2003 09:55 PM
Propane Usage COArgosy78 On The Road... 6 02-25-2003 09:35 PM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
