03-03-2015, 01:51 PM
2013 28' Flying Cloud
Cohasset
, Massachusetts
Propane quick-connect
Hi folks,
I want add a catalytic heater to my FC28. I'd like to use the front propane tanks and run a hose into the "cabin".
Anyone know if there is a quick-connect fitting from the propane bottles on an Airstream and what size it is? I seem to recall seeing something that would allow the use of a gas grill…
I have to ask because my trailer is in storage, snow-bound, about 35 mi away. Anyone have any experience with this set-up?
Thanks, Dave
03-03-2015, 02:09 PM
1988 29' Excella
Plant City
They make tee that connects to propane bottle . I think you would need a regulator installed if you run a line from the bottle to your heater. My catalytic heater is tapped into the propane line behind refrigerator with a copper line run to the heater its mounted on the cabinet next to the refrigerator
03-03-2015, 02:18 PM
2002 30' Classic S/O
Fleming Island
Best bet is to send a contact message to airstream on their web site. Give them the VIN and ask. Mine (2001) did not have one, but I think some of the newer trailers may.
Also, you could add, or have added, a tee at the furnace or stove inside the trailer so you don't have to run another line. However, if the heater runs off of the small bottles and has the regulator built-in to the heater instead of external, you will need a direct, high pressure line. That may be a code violation and sounds like a bad idea to me.
Al
03-03-2015, 02:59 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
Your trailer's propane connections (regrigerator and cooktop) operate under low pressure delivery.
Catalytic heaters are also low pressure devices, so I would look toward using one of the existing connections inside the trailer.
03-03-2015, 03:34 PM
Cohasset
, Massachusetts
Thanks for your replies.
I found this article about heaters and am thinking of using a Mr. Heater Portable Buddy(which can use either the small bottles or a hose and quick-connect): RV Heater: How to Install a Vent-Free Propane Heater in an RV
I'm not sure if I can get to any of the propane lines inside, which is why I thought I'd look into a flexible hose from the outside tanks.
03-03-2015, 04:55 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Actually, no. ou don't get to use ventless catalytic heaters in an RV. That's according to NFPA 1192, as adopted by the RVIA:
Fuel Systems and Equipment as specified in ANSI/NFPA 1192 Standard on RV’s:
*Propane line routing and accessibility - all joints in propane lines must be accessible for periodic leak testing and repair. Lines may not be installed in spaces where a nail or screw could pierce the line.
*Fuel burning appliances must be listed for RV use and labeled by a nationally recognized testing agency that has found the product to be suitable for its intended use.
*Sealed combustion and direct venting to the outside is required for all propane appliances, except for gas ranges, to provide for a complete separation of the combustion chamber from the interior atmosphere.
*Each propane system must be tested upon final assembly to determine proper leak-free performance.
Just because you found instructions on the Internet doesn't mean you should do it.
03-03-2015, 05:31 PM
2002 31' Classic
Monroe
, Iowa
I don't know much about it, but my dad's '70s 31' AS had a cat. heater mounted on the side of the cabinet above the furnace ducts, as you come in the door.
That AS was a custom ordered one from Airstream. I think it came that way from Airstream.
03-03-2015, 05:36 PM
2007 22' International CCD
Corona
That was legit then. No longer. Too many folks killed by fume buildup.
03-04-2015, 12:24 PM
Cohasset
, Massachusetts
Thanks all for your replies.
I want share this answer I just received from the manufacturer, regarding the Portable Buddy Heater:
"Dave
•This unit can be used in a travel trailer. It comes equipped with an oxygen sensor, it will shut itself down when the oxygen level in the air gets too low. This feature allows it to be used inside any enclosed area without any worry of harmful fumes filling the air.
•Secondly, you can connect this unit to any source of propane other than the 1lb tank by using a propane hose. This unit comes equipped with an internal regulator, so whatever hose you use will not need a regulator attached to it. You simply screw the hose into the regulator where you would normally screw the 1lb propane tank to.
•Make sure you purchase a fuel filter for this unit (f273699) if you do decide to use a propane hose. Most propane hoses contain a plasticizer that allow them to stay flexible over time, and this plasticizer contains oily deposits that grab on to the propane gas as it moves through the hose. The deposits then will contaminate the heater and its components and over time build up and create operating problems.
•Simply screw the filter into the internal regulator of the heater, and then screw the hose into the filter. We sell a hose that does not contain any harmful plasticizers, and that is buddy hose part number (f273704).
•We recommend using the fuel filter with the use of any other hose with this heater, because we don’t know how any other hose is made. I hope this was helpful. Have a great day."
Wallace: 2013 GMC Sierra 2500 D-Max
Gromit: 2013 Flying Cloud 28
_______________________________
03-04-2015, 01:22 PM
From All Over
It still doesn't comply with NFPA 1192, and isn't labeled for RV use. But since I'm not going to come to your home and stop you from using it, you can use it or not as you think best.
So it has an oxygen sensor. What is the sensor set for? What percentage of O2 in the air causes the heater to shut off? If you don't know, you should find out before relying upon it.
Don't rely just on the heater's safety systems, though. Make sure your LPG and CO detectors are in good working order.
If connecting to a low-pressure source, you'll need to remove the unit's regulator, otherwise you'll have problems from trying to regulate an already-low-pressure feed. Also, standard practice is to use copper tubing for all wall/floor penetrations by propane lines, with rubber or plastic grommets to prevent the edges of the hole from chafing against the tubing. It's also standard practice to make no joints at all inside the trailer, except for the joint between the copper tubing and the appliance itself. In other words, all taps into your existing propane system should be performed under the trailer, not inside the trailer.
That's a new one on me. Every trailer ever made has flexible hoses connecting the cylinders to the trailer's gas plumbing, and I don't know of anyone who filters the propane.
As I stated above, if you connect to a low-pressure feed, you'll need to remove the internal pressure regulator. That may leave you nowhere to attach a filter.
I'm not trying to bust your chops, however it may seem. As I said, I can't and won't stop you if you want to use a heater that's not approved for RV use. I just want to make sure that whatever you decide, you do it with full knowledge of both the pros and cons of your choice.
03-04-2015, 02:30 PM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
I would not use a cat heater in an enclosed area such as an RV. Just way too much can go south in a big hurry. The furnace works fine, we have two AC which also act as heat pumps as long as it not too cold outside.
I've seen the results of a cat heater accident in an enclosed golf car, not pretty.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
03-04-2015, 03:17 PM
Biloxi
, Mississippi
I used a cat heater for two winters in my Bambi II. Still alive to post about it.
MICHAEL
03-04-2015, 03:31 PM
From All Over
All catalytic heaters are not created equal, and just because one make/model has been used safely by you don't necessarily mean that another make/model can be used safely.
Every person who wishes to use an aftermarket heater— especially a propane-fueled one that isn't vented to the outside— should perform due diligence by thoroughly researching the product and its requirements for safe use before proceeding. Recommendations from other users is part of that research, of course, so if you've safely and successfully used one it would be helpful to give the make/model of the one you used.
03-04-2015, 03:57 PM
Biloxi
, Mississippi
MICHAEL
03-04-2015, 04:28 PM
From All Over
Thank you. Camco caters specifically to the RV market, so it's generally a good bet that a Camco product can be safely used in an RV, if installed in accordance with manufacturer's recommendations.
You have also proved my point about all catalytic heaters not being equal. From your linked Amazon webpage:
Heaters are designed to operate with a manifold pressure (the gas pressure downstream from the appliance controls) of 11" WC (0.40 psig). In addition, the supply line must be equipped at the cylinder with a listed low pressure regulator set to deliver the specified pressure.
In other words, it's designed to be plumbed into an RV's propane system. It doesn't have its own separate built-in regulator like the heater the OP cited; it only has a valve to control the heat, just like on a propane stove; the regulator has to be at the cylinder.
03-04-2015, 05:15 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Protag - thanks for being so thoughtful about your replies. One thing about an "oxygen sensor" that we should ALL remember - is "so what?" Carbon MONOXIDE doesn't need to deplete all the oxygen in the air to kill you - carbon DIOXIDE sorta does. Carbon MONOXIDE bonds with the hemoglobin in your blood and prevents the blood from picking up any oxygen while circulating through the lungs.
If you have a lovely rosy blush after a week in a trailer - those rosy cheeks are one symptom of CO (carbon monoxide) poisoning.
Once carbon monoxide gets into your blood it's only eliminated as your body makes new blood cells - or by a doctor doing transfusions. It can take months to fully recover from CO.
So - I want one of those, but I'm not dying to have one!
Paula
03-05-2015, 03:39 PM
Cohasset
, Massachusetts
Hi Protagonist
Just want to thank you for your replies to my OP. Your points are well taken - exactly why I posted in the first place.
Dave
03-05-2015, 05:39 PM
1972 27' Overlander
Denver
, North Carolina
I need an opinion as I reinstalled my furnace in the trailer last weekend ahhhhhhh...warmth. I am also installing a Camco wave 6. I want to use the rubber (?) gas line also from Camco, from the back of the heater to a Tee installed in the line next to the heater. pros. Cons?
Dave
Lucky Dave, Denver NC
03-05-2015, 06:00 PM
Biloxi
, Mississippi
When I installed the cat heater in my Bambi II I mounted it in the space the old heater was removed from. I hinged the panel to access a huge wasted storage space. The local gas shop made up a flexible hose for the application. The hose was made from a material that was designed to be used in an application like this. Zero apparent wear in two years of use. I am sure that someone will quote some code or something saying that this was illegal.
MICHAEL
