Old 03-21-2019, 05:54 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Propane Pigtails Source
Need some help. I searched and read through a number of posts about the pigtails running from my automatic propane switchover to the 2 30# tanks on my trailer. Still can't find a source. I need a replacement for a Marshal Gas Controls Flexible Hose Model A4 PN HP424, 12 Inches. If anyone knows where I can find this please let me know. From other conversations it sounded like Airstream can't supply them so I didn't really check. Will try tomorrow.
Would appreciate hearing from you. DH
Emh142 is offline   Reply With Quote
Old 03-21-2019, 06:54 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Go to/call etrailers.com. They have what you need.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 03-21-2019, 07:14 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
You will not find that exact part number. Since Marshall is now Marshall Excelsior, the numbers changed. No longer USA made.
What you need to know before ordering is the type of connection threads into the regulator (NPT or reversed flare)
The connector nut to the tank is Acme.
When I changed mine I used hoses a couple inches longer than the originals. This made alignment easier when connecting and disconnecting when refilling the tank.
This is the brand I used because they are made in USA. (and Canada) And, they have all of the built in safety features (see video at weblink below)
Maybe this is what you need? https://www.etrailer.com/Propane/MB-...100473-12.html
ps:
The rubber diaphragm inside the regulator has a life limit. If 10 years or more old, time to change
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 03-21-2019, 07:52 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I looked up my order. This is what I used:
https://www.etrailer.com/Propane/MB_...73-15-MBS.html
Alan
Old 03-21-2019, 10:39 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Installed last Season.......
On our new regulator.....👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-21-2019, 11:07 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the local propane store made new hoses for me.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-22-2019, 08:19 AM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
I bought new ones a couple of years ago from an eBay vendor. I had no trouble finding what I needed.
CRH is offline   Reply With Quote
Old 03-22-2019, 11:10 AM   #8
PopHetzler
Emh142's Avatar
Troy , Ohio
The problem seems to be 1/4 inch flared vs. the stock 3/8 flat connector to the regulator. How did you all manage that? With some sort of adaptor? I haven't seen anything on this yet. Thanks again. DH.
Old 03-22-2019, 03:16 PM   #9
PopHetzler
Emh142's Avatar
Troy , Ohio
Done. I gave up and went to the 1/4 inch with and adaptor. Finding the right adaptor was a real chore. Most people can't figure out the different types of threads. DH.
Old 03-22-2019, 04:35 PM   #10
This help?
W. H. Auden
Amanamus
"Tahawus"
Old 03-26-2019, 05:02 PM   #11
Steamguy's Avatar
2019 27' International
Washougal , Washington
Ok, I see you found a solution. I was about to recommend your local 'fireplace shop'; I've had a few projects and they were most helpful.
(Our house is plumbed for propane for the range top, for an outside firepit, and will soon have the fireplace converted.)
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Propane Pigtails Picinisco LP Gas, Piping, Tanks & Regulators 6 06-17-2017 09:37 AM
Replacing pigtails on'86 32' excella rbhinzman LP Gas, Piping, Tanks & Regulators 1 08-25-2014 11:00 AM
Marshall pigtails with 3/8" male fitting 2goldens LP Gas, Piping, Tanks & Regulators 4 04-03-2014 09:46 PM
Need Quick Disconnect Battery Pigtails sharris1199 Batteries, Univolts, Converters & Inverters 9 08-05-2009 10:46 PM
Old 1/4" pigtails don't fit new 1/4" regulator? longdog LP Gas, Piping, Tanks & Regulators 1 04-22-2009 08:56 PM
