Old 09-06-2016, 09:42 AM   #1
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Propane pigtail hose connector is leaking
How hard is the propane pigtail hose connector to replace?
It looks very straightforward with parts readily available.
Looks like 12" is the standard length.
Seems like longer than 12" would be OK but shorter would be terrible-
Is Teflon tape required?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-06-2016, 10:25 AM   #2
1976 31' Sovereign
Oswego , Illinois
Smile
No there is inverted flare on regulator end. Simply screw pig tail off regulator screw new one on put little soapy water to check for leaks if desired. I never do, never had one leak if so could smell gas. Use what ever length hose you need longer okay but more money. Bill
Old 09-06-2016, 10:30 AM   #3
Boxite's Avatar
2008 22' Sport
Two things to consider when replacing the pigtails:
My originals were only 10" long, so the next size I could find was 12" and that's what I ordered. In actual fact, the 20" would have been easier, by forming a "loop" in the hose would have allowed the tanks to remain in their exact same position. The 12" were only slightly longer than the originals...but installing them req'd a VERY-tight bend....possibly leading to future damage/leak... so I had to "rotate outboard" the tanks... so their valves faced slightly outboard instead of straight aft.... in order to allow the 12" pigtails to only curve gently to the regulator.
BTW, the originals were made by Marshall (MEC) and that's also what I ordered online from Amazon...at half the price otherwise available.
SECOND consideration: Be certain of the end-connection. Mine were NOT the common "inverse flare"...but were ordinary 1/4" NPT (National Pipe Thread...which have a slight taper to a plain end.) The "inverse flare" is intended for threading into another brass fitting, which will adapt that flare to the regulator...which is ordinary NPT (at least in most regulators.)
AND if you do have NPT you will need to use some pipe-dope (my preference) or yellow Teflon tape.
Hope this helps.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-06-2016, 10:40 AM   #4
m.hony's Avatar
2013 30' Classic
So...
Maybe I will get 20" pigtails and make a loop or turn the tanks further out?
The longer pigtail will also come in handy if I ever decide to install gauges other than what are already on the tanks or connected to the monitor inside the trailer. I don't really trust the gauges that are on the tank and I don't really trust the MicroPulse monitor in the trailer.
Lifting the tanks or taping the tanks seems to be as good a method as any for checking the LPG level.
TAC #MS-10
Airforums #70955
Old 09-06-2016, 12:42 PM   #5
1979 23' Safari
Wayland , New York
So...
If the tanks have the gauges screwed into the top of the tank itself with dial gauge levels. Those are usually very reliable. If they are the ones that connect to the tank propane outlet in line to the pigtail, they are usually pretty accurate when levels start to get low but it's a quick curve.
Old 09-06-2016, 12:56 PM   #6
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Ditto Boxite on the Teflon. Neither the white or pink tape is considered appropriate for natural gas or LP. The yellow is double thickness and is intended for gas connections.
GammaDog is offline   Reply With Quote
Old 09-06-2016, 01:19 PM   #7
m.hony's Avatar
2013 30' Classic
The gauges are part of the tank.
There is also a sensor for the MicroPulse Monitor.
I'm sure the gauges on the tank are more accurate than the MicroPulse.
It automatically switches from one tank to the other when one gets empty.
TAC #MS-10
Airforums #70955
Old 09-06-2016, 02:00 PM   #8
1977 31' Sovereign
Lynnwood , Washington
Visit etrailer.com.
Order two. Get the length you like. Save old hose for a spare.
Tom
TomKirk is offline   Reply With Quote
Old 09-06-2016, 02:11 PM   #9
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
As Boxite said, my originals were just pipe thread. All of the pigtails I could find were inverse flare, so I had to buy adaptors.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-06-2016, 02:16 PM   #10
1973 25' Tradewind
Redding , California
I put a little yellow gas teflon tape on the to make the threads snug, just be sure that no tape covers any part of the flare fitting. also... I just replaced both my tanks because these fittings were leaking at the tank. I had just completed re-certifying the tanks, they were original 1973 tanks. The service peeps don't check the gaskets on the tanks as part of the recert process. if your hoses are leaking at the tanks it may be the tanks. changing these hoses is about a 5 minute ordeal.
Leadvox is offline   Reply With Quote
Old 09-06-2016, 02:22 PM   #11
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
teflon tape
I was told the reason to only use yellow is because gas fixture orifices are tiny and the other color teflon can shred and clog those if any it get into the line. Openings in water lines are huge by comparison. I used white on mine once and had to replace the heater pilot because it became completely blocked.
rvb is offline   Reply With Quote
Old 09-06-2016, 03:12 PM   #12
m.hony's Avatar
2013 30' Classic
Maybe I should remove the pigtail first and lie it on the counter at the hardware store?
TAC #MS-10
Airforums #70955
Old 09-06-2016, 03:46 PM   #13
1976 31' Sovereign
Oswego , Illinois
Cool
Where are gaskets on tanks? All propane cylinders including 500 gal. or larger the valve screws into tanks, no gaskets then lines go to regulator. New parts are less money than tanks.
Old 09-06-2016, 04:20 PM   #14
m.hony's Avatar
2013 30' Classic
The line/hose itself is leaking at the fitting with the hex head on the regulator end.
I think new pigtail hose connectors will take care of it.
Only one side is leaking now, but my mind says they are both the same age.
TAC #MS-10
Airforums #70955
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 12:38 PM
Defective Propane Pigtail Lines vswingfield LP Gas, Piping, Tanks & Regulators 10 02-21-2012 02:20 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 09:12 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 09:25 PM
