Old 05-04-2014, 01:35 PM   #1
1968 26' Overlander
Wolfforth , Texas
Propane lines on the bottom? Were these original?
Name:	ImageUploadedByAirstream Forums1399232136.573391.jpg
lakoria is offline   Reply With Quote
Old 05-04-2014, 01:41 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Not sure if that particular configuration is original, but propane lines are run on the outside so that if there's a leak gas doesn't build up inside the bellypan below the floor.
TB & Greg and Abbey Schnauzer
#3954
Old 05-04-2014, 01:46 PM   #3
1974 Argosy 20
Kooskia , Idaho
Yes, propane is heavier than air, so the lines are always run outside of the bellypan. There should also be a shutoff for each appliance on the outside with the old trailers. A single piece of copper line (with no joints) is then run up and into the appliance itself. Sometimes there is a second shutoff at or in the appliance, but not always.
Old 05-04-2014, 02:43 PM   #4
aquinob's Avatar
Portsmouth , Virginia
Just finished up reconnecting all the propane lines on my '73 so I'm pretty familiar with what they look like and I would say yes, those are probably original. Looks like you have gas appliances on both sides hence the crossways look. On mine, only the fridge and the water heater were opposite so it was mostly on the curbside of the trailer.
I gotta ask though, how high is that trailer jacked up in the front? Looks like its sitting on the rear bumper. That cant be good for the plumbing back there, though it does make a nice cave for the pooch.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 05-04-2014, 08:31 PM   #5
1968 26' Overlander
Wolfforth , Texas
Wow! We couldn't believe they were original! Someone used a jack and flattened the front line. We are going all electric so we're taking them off.Click image for larger version
Name:	ImageUploadedByAirstream Forums1399257104.234015.jpg
As to being lifted it was almost to bumper using a forklift. All plumbing (everything actually) has already been removed.
Old 05-06-2014, 08:11 AM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I'd offer some words of caution with your jacking/lifting technique. These trailer frames have a lot of flex in them, and you are putting the whole unit in a very unnatural position, basically suspending it from the extreme ends. A 50 year old frame may very well be rusting through inside of that bellypan, and if it lets loose, not only could you turn your trailer into a fortune cookie, but if anyone is under it, really bad stuff will likely happen. A much safer way to go would be to jack each side of the trailer up, and slip some bricks/stacks of planks, etc., under the wheels. I found that with a stack of two 2x12s under each side of my trailer I had plenty of room to roll around under the trailer on a mechanic's creeper.
good luck!
Old 05-06-2014, 09:42 AM   #7
1968 26' Overlander
Wolfforth , Texas
Thanks but believe me safety is always number one! What you are not seeing is the 2 extra safety catches
Old 05-07-2014, 03:18 PM   #8
1963 19' Globetrotter
Moline , Illinois
Be safe
NEVER, EVER , use cement blocks or bricks to raise a trailer or vehicle ! Jack stands or wood cribbing are the proper ways to do it. I can assure you that recovering the body when they fail is not a pleasant experience.
63air is offline   Reply With Quote
Old 05-07-2014, 03:40 PM   #9
1976 31' Sovereign
Oswego , Illinois
Smile
good luck!
You stated to jack up then put 2/12 under wheels, just stack 2/12s then pull on top safer than jacking up, if they slip use single 2/12 pull onto then onto stack I have did it this way since 1950s w/impl. trailers then AS since 1963
Old 05-07-2014, 08:55 PM   #10
Belegedhel's Avatar
Houston , Texas
Well, at the risk of steering this thread completely off track, let me try to reemphasize the point I was trying to make. If you haven't dropped the belly pan, you never know what shape your frame is in. I mean only to propose that having the weight of the trailer on the axles, and the wheels elevated, whether they get elevated by jacking up the trailer and putting planks under it, or by rolling the trailer up onto planks, patio bricks, bars of gold, etc. might be a safer way to give yourself some room to work under a trailer.
The frame on my '73 was so rotten that the rear 4 feet had to be replaced entirely, and the front had to be repaired extensively. You never would have guessed by just looking up under there, though. Had I put a jack stand under each frame rail where it meets the bumper, and lifted the A-frame with a forklift, the thing probably would have folded up like a fortune cookie, and anyone underneath wouldn't have to read the fortune to tell that their luck had run out.
Anyway sorry for the highjacking.
Where do these other water lines go? adwriter73 Plumbing - Systems & Fixtures 9 09-28-2010 09:08 PM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 03:45 PM
propane lines airtim LP Gas, Piping, Tanks & Regulators 18 03-26-2005 07:38 AM
What were the original window covers or shades?? IPM Airstream Motorhome Forums 3 04-07-2004 07:25 PM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
